CPU Just achieved a very moderate undervolt/overclock on my Phenom II X4
Discussion in 'Hardware' started by Oggyb, 17 Apr 2012.
  1. Oggyb
    Oggyb Mutant
    15 Jun 2010
    Moving house soon to a place where the electric is metered, so every penny saved is worthwhile.
    I successfully lowered my 955 BE's vcore from 1.4 to 1.28 and pushed the clock from 3.2 to 3.3GHz at the same time.
    HWMonitor is reporting CPU temp drops of 10 degrees C, though I don't trust its accuracy. I know it's not the greatest achievement in the world of clocks and voltages, but it's my first CPU tweak and I'm proud of it :D
  2. improprietary
    improprietary FT03 is a bitch to watercool
    13 May 2011
    wohoo! Congratulations! :)
  3. Throbbi
    Throbbi What's a Dremel?
    10 Sep 2009
    While the o/c isn't much the undervolt is a fair chunk, should help bills a bit but I think it might start to splutter if pushed. Nice job regardless though :thumb:
  4. Guest-44432
    Guest-44432 Guest
    Try running Intel Burn test (IBT) to test for stability. Report back With CPU-Z and IBT screens shots. :)
  5. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    To add on to that, run IBT on Maximum stress setting.
  6. j4mi3
    j4mi3 What's a Dremel?
    28 Jun 2011
    maximum is the only real way to test it ;)
    a test which separates the men from the boys
  7. Oggyb
    Oggyb Mutant
    15 Jun 2010
    Sad news, the undervolt is lovely but is not sustainable with my music work, which pushes into the red a little quickly.
    Will post screenshots when I've reached something sonically stable.
  8. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    I managed 1.15V @ 3.4 on my FX 8120 before my board blew. Didn't seem to care in the slightest. I do wonder if I have an 8150 that was only ever so slightly out of spec.
    Anyway; Back ontopic; that's a ridiculous reduction. I've heard stories of 955s and the like doing 3.8 on stock voltage, but never 3.4 on that little!
  9. Oggyb
    Oggyb Mutant
    15 Jun 2010
    Before I continue I just want to mention that for the purpose of general web browsing and office duties, my initial 1.28V/3.3GHz tweak was functionally stable, and I'd have no worry going with that when the time comes to relegate this CPU/mobo to family or fileserving duties. Obviously it's no good for extreme activity.
    Here's a screenshot of my PC playing back a heavy orchestral arrangement at low voltage with no difficulty, probably the highest my real-world usage will go:
    BIOS setting = 1.35V
    Here's a screenshot of the standard IBT result, showing the nominal stable voltage in CPUZ. Interestingly, HWMonitor notes a lowest voltage of 0.96, and that's because it throttled back one or two times in the test.
    BIOS setting = 1.365V
    I tried running the test on maximum, but after seeing CPUZ show the multiplier drop to 4x every few seconds I decided my cooling wasn't up to this kind of testing, so I stopped it before I broke something.
    Should I keep it at 1.365V BIOS setting or go back to my "work stable" 1.35V?
  10. noizdaemon666
    15 Jun 2010
    Keep it at 1.365. Just because it's currently work stable at less doesn't mean it will stay that way. If it isn't completely stable it could blue screen at any time.
  11. .//TuNdRa
    12 Feb 2011
    That Gigaflops report must be a little off, no?
    That or bulldozer really really doesn't like that test. I only got 12 Gflops when I ran it. Consequently; I don't bother with it. Extreme takes over half a day to complete.
  12. Oggyb
    Oggyb Mutant
    15 Jun 2010
    Ha yes, I chose to ignore the time and gigaflops results!
    Fine, I shall stick with the current standard-stable setting. Thanks :)
