Case Mod - In Progress The Witcher Mod - Jon & Ron - Final Pictures
Discussion in 'Project Logs' started by Pennywise, 8 Jan 2016.
  1. Pennywise
    Pennywise Minimodder
    6 Nov 2011
    We would like to give a huge thanks to all our sponsor.
    You guys didn't even hesitate to donate to such a great cause.
    This wouldnt be possible with out you.
    Ron and I are very excited to get started on this and look forward to all the feedback.
    Jon (PennyWise) Hansz
    http://NerdRagePros.com
    Ron Lee Christianson
    http://bluehorse-studios.com/
  2. jojoharalds
    jojoharalds Minimodder
    30 Apr 2014
    subbed!!!
    Sent from my SM-G920F using Tapatalk
  3. Darkwisdom
    Darkwisdom Level 99 Retro Nerd
    27 Aug 2011
    Rule 2: Your first post must be a work in progress, not just a heap of parts and some rough sketches. The general idea here is to maintain the high quality content we’re all used to.
  4. jojoharalds
    30 Apr 2014
    Haha if you put it like that and since u mentioned it....
    i do have to agree with that.
    i got that once. i really wanted to keep a clean buildlog but instead i got tons of messages tellimg me about pictures wkth workprogress..
    Aren't we all supposed to be at the same level.
    or are most of us here secpn and third class .
    while others are like somewhat of ROYALTY...
    I am just asking to make sire
    I really couldnt care less but it was an intersting point to mention.
  5. GeorgeK
    18 Sep 2010
    Moved until there is something happening...
  6. Pennywise
    6 Nov 2011
    I forgot to mention a little about the build.
    This will be 1 of 5 mods being raffled off at the next PDXLAN.
    All proceeds will be going to The Phil Scholz Foundation.
    I should have some pictures up tonight for you guys.
  7. Pennywise
    6 Nov 2011
    Here is what we started with.
    We also had other sponsor that donated to our build.
    Nvidia Geforce Garage
    Intel
    Caselabs
    Koolance
    Crucial
    Thermaltake. When the rest arrive I will picture the Ring fans.
    PrimoChill
    Western Digital
    TAP Plastics
    There are couple other products that are coming in later.
    I will post pictures once they come in.
  8. Pennywise
    6 Nov 2011
    I'm a little old school when it comes to designing a case and coming up with ideas.
    Once I have an idea, I use transfer tape and draw it up on the case.
    Keep in mind, they are quick rough sketches.
  9. Pennywise
    6 Nov 2011
    So lets get things started.
    I used a piece of transfer tape to copy about the same image on to another piece.
    Now I have a flat surface to work on.
    Using sculpey, I will be making a general shape of what I want the face to look like.
  10. Pennywise
    6 Nov 2011
    Time to make the Donuts...
    I pulled the clay up with the transfer tape.
    Trimmed the edges a little.
    Placed on some tin foil and upside down cookie sheet.
    Put it on 275 about 40 minutes.
    It is thicker in some areas, so the middle wont harden as much as you would think.
    I am just looking for the outside to be a little stronger.
    Trimmed the edges up a bit and placed it on my make shift vacume former.
    Its not great, but does the job and it didnt take alot of time to build.
    Heated up the 1/8" plastic in a window frame.
    I put metal tabs on each side and just put it in my home oven.
    Now I have a basic form of the face that is light weight and can be attached to the front of the case easily.
    If I had used the clay, the case would have weighed a ton.
    I also wanted to keep Caselabs Panel design functional.
    and with the custom res. I got planned, it will be heavy enough.
  11. jojoharalds
    30 Apr 2014
    looking awsome!!
  12. BLAMM0
    BLAMM0 What's a Dremel?
    28 Jul 2014
    You live and you learn, thanks for this lesson (y)
  13. Pennywise
    6 Nov 2011
    Ok, let get down to the bulk of the body work on the outside of the case.
    I will be doing all the detail work on top of the vacume form with some magisculpt.
    The trick with this is doing it in stages and layers.
    I am going for more of a rough look as its meant to look like it was in battle.
    So I plan to leave it somewhat rough.
    Ron will work his magic with the airbrush when its ready for paint.
    I cut out the image from the plastic were I need to do detail work on.
    Then I riveted it on to the front panel.
    The bays were covered to keep most of the magisculpt off to prevent it from sticking.
  14. Pennywise
    6 Nov 2011
    Most of the face has been formed with some of the detail work.
    As parts hardened, I added more around it and on top of it.
  15. Pennywise
    6 Nov 2011
    Using some more plastic, I used a heat gun and formed it to were the teeth are going to go.
    I drew on some teeth, then cut them out.
    Also cut away some of the magisculpt from the gum line so they sit back in further.
    There is just tape holding them on right now for the last picture.
  16. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    Subbed!
  17. Pennywise
    6 Nov 2011
    I attached the teeth with rivets to the vacume formed face.
    Using more magisculpt, I built out the teeth, and culpted the gum line.
  18. Pennywise
    6 Nov 2011
    The face now is blended around to the sides of the case on both sides.
    on the left side I have been using up the left over magisculpt from other areas.
    This will prevent alot of waste.
    I have drawn on a rough sketch of what I want the trees to look like on the left.
    I have also started sculpting them in.
  19. Pennywise
    6 Nov 2011
    I built up the trees out of the side of the case to frame in were the window is.
    Plus did a little work on other parts of the face.
  20. eucalyptus
    eucalyptus I am 19 and Swedish!
    29 Sep 2015
    O M G! This is something I never seen before :D
    I LOVE the trees! So excited to see what you can do with them and how they turn out!!!! :)
    Please don't keep us on hold ;)
