Bits Lian Li V1020, V2120 preview
Discussion in 'Article Discussion' started by Claave, 25 Aug 2010.
  1. Claave
    Claave You Rebel scum
    29 Nov 2008
  2. SouperAndy
    SouperAndy To Bumble or not to Bumble?
    16 Feb 2009
    In the immortal words of Al Murray:
    "Filfy" (drool)
    SouperAndy :worried:
  3. [PUNK] crompers
    [PUNK] crompers Dremedial
    20 May 2008
    is that pink? sure looks pink.
    both gorgeous cases though, the V1 looks amazing, if a little large.
  4. rickysio
    rickysio N900 | HJE900
    6 Jun 2009
    Err, wheels...?
  5. KayDat
    KayDat What's a Dremel?
    20 Nov 2006
    Gorgeous aluminium cases...but so expensive. I'll just have to be content with my Antec steel cases... =/
  6. coolmiester
    coolmiester Coolermaster Legend
    31 Dec 2002
    Good to know, looking forward to seeing what they come up with.
  7. Jipa
    5 Feb 2004
    Wohoo for the perforated comeback! And thanks for throwing my question at them as well :)
    About the PC-V1020 looks great, but having a single huge HDD-rack instead of being able to split it half-way is a huge minus. It's hard to tell from the pictures how well graphic cards will fit, but with under 7 hard drives I'd much rather throw half of the cage out in order to have better airflow from the fan.. Like so:
  8. PureSilver
    PureSilver E-tailer Tailor
    16 Dec 2008
    Hurrah! Finally, a cheesegrater that doesn't turn my motherboard upside down and defeat the point of heatpipe cooling systems. The question now is only can I justify selling my current case to buy one that looks almost identical...
  9. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    WAAAAAAGH
  10. DBA
    DBA I do my modding with a spoon
    18 Feb 2009
    It's quite funny how you can consider yourself a fan of something you have never even seen in real life.
    It's really good to see a return of the removable motherboard tray and, depending on the price, the V1 in red could very well be my next case (otherwise it will be either the A05 or B25)
  11. StoneyMahoney
    StoneyMahoney What's a Dremel?
    10 Jul 2009
    Mac Pro-a-like my arse. No-one who ever used on gave a damn about the outside, it was the internals that made it fantastic. Never poked around inside a more friendly system in my life.
  12. rehk
    rehk What's a Dremel?
    21 Feb 2010
    Good to hear that Lancool are doing good. I'd love to see more Lian Li cases but made of steel for cheapness, like how the K62 was essentially a PCP50 but with some minor changes such as a dedicated 3.5inch drive rack instead of 5.25>3.5 inch adapters.
    Also the red outside black inside color scheme looks brilliant.
  13. SNIPERMikeUK
    SNIPERMikeUK What's a Dremel?
    21 Feb 2006
    Lian-Li should make an arcade fight stick case for sanwa parts....Imagine the craftsmanship....
  14. Lance
    Lance Ender of discussions.
    6 May 2010
    Really want one of those. V1020's. Just not in pink. Maybe as a next case..... I do need to replace mine at some point, pity it doesn't support watercooling though as that was my plan.
  15. Pete J
    Pete J Employed scum
    28 Sep 2009
    Ohh, I like the V2120!
  16. Hakuren
    Hakuren What's a Dremel?
    17 Aug 2010
    Keep in mind that V1020 in dusty environment is a bad idea (had one from older model). It looks really bad because mesh is constantly "attacked" by dust, and keeping it clean is a full time job.
    If someone want water cooling - in particular with more than 1 loop - then Lian-Li is not the way to go. Pick a Mountain Mods case (in Europe only available - with delay - from aquatunning.de). You get 15mm fan spacing in standard, perfect for every radiator. You don't need any DIY to install WC system in MM box.
  17. Zinfandel
    Zinfandel Modder
    2 Aug 2010
    Do you work for MM? That's twice now.
    1020 looks lubberly.
  18. Guest-16
    Guest-16 Guest
    It's not pink, it's a deeper red. ;) Just strip lights make colour correction very difficult.
  19. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    drooool, dribbbble <wipes mouth>...
    Looking forward to seeing the 4 bay NAS box and the black V1020.
  20. murtoz
    murtoz Busy procrastinating
    9 Apr 2008
    +1
    Was going to ask the same thing after the first time...
Tags: Add Tags
