Asus P6T7 motherboard
Discussion in 'bit-tech Folding Team' started by Christopher N. Lew, 1 May 2009.
  1. Christopher N. Lew
    Christopher N. Lew Folding in memory of my father
    23 Apr 2009
  2. JackOfAll
    JackOfAll What's a Dremel?
    23 Apr 2009
    Not close enough! ;)
  3. spunkymonkey
    spunkymonkey phoenicis wannabe
    24 Apr 2009
    its bloody lovely but imagine trying to find and power up 7 single slot gpus that are decent folders :jawdrop:
    cheers spunky
  4. 1Razor
    1Razor Living life one day at a time....
    24 Apr 2009
    Or even 4* GTX 295's, 2 PSU's or one very big one (1500W?) not sure if there would be enough 6+8 supply lines. Still wouldn't mind being able to afford one though! :D
  5. JackOfAll
    23 Apr 2009
    I did a little research on that myself and I couldn't find a 1500W (or above) with 4x 6pin and 4x 8pin. I'd be interested if anyone knows of one.
  6. Christopher N. Lew
    23 Apr 2009
    I tried to find one, but decided it would have to be a 2 PSU machine.
  7. saspro
    saspro IT monkey
    23 Apr 2009
    According to a guy on the nvidia forums
    Thermaltake ToughPower 1500W: 4 x 6-pin + 4 x 8-pin P, 12V rails total 120 Amp’s
    Cooler Master Real Power Pro 1250W: 6 x 6-pin + 3 x 8-pin, You have to combine two 6-pin to one 8-pin, 12V rail total power 128 Amp’s;
    Enermax Revolution 1250 EGT: 8 x 6+2-pin PCI-E, 6 rails a’ 30 Amp.
  8. Christopher N. Lew
    23 Apr 2009
    I'm using one of these to drive a K9A2 system with 4*9800GX2 cards, and it is barely warm to the touch (which may just be the warm ambient air), and quieter than my Corsair 1000w. If I were to go into "crazy configuration land (population: you)" and try to run 7*GTX295 cards, I would be thinking about two of the Enemax PSUs, but maybe the 1250 + 1050.
    Of course, efficiency and quietness pale into insignificance next to the 9800GX2s, but its comforting that at least one component is not being pushed to its limits.
  9. JackOfAll
    23 Apr 2009
    Now I'm confused! ;)
    Christopher, you tried to find a PSU with 4x6pin and 4x8pin but decided it would have to be 2 PSU's. Then saspro flags up the Enermax Revolution 1250 with 8x 6+2. And you're already using this? Yep, I'm confused. Chuckle.
    Anyway, thanks saspro. I'll do a little more research to see how the rails are arranged on those.
  10. Turbotab
    Turbotab I don't touch type, I tard type
    4 Feb 2009
    7 GTX 295, holy poo. How many GTX 295s in SLI can the board support, still 'only' 2?
    Does anybody remember the University of Antwerp's quad 9800GX2 set-up, those guys must be salivating at the thought of 7 GTX 295s.
  11. JackOfAll
    23 Apr 2009
    Only 2 in SLI, but SLI isn't enabled for folding. But anyway, you can still only fit 4x GTX295 on this board, it being a double slot card. (Or pay a fortune for bus extenders, I suppose.)
  12. Christopher N. Lew
    23 Apr 2009
    Sorry, JackOfAll, if I didn't make myself clear. Yes, the enermax has 4*6+8 pins, and as I say, runs 4*9800GX2 fine. I don't know from experience if it would power 4*GTX295.
    But the machine I had in mind when deciding on 2 PSU, was the hypothetical 7*GTX295
  13. Turbotab
    4 Feb 2009
    Ah, true, silly me got carried away. Maybe if Nvidia ever releases a single PCB GTX 295, uber folders might be able to slot in 7 of them:sigh:
  14. JackOfAll
    23 Apr 2009
    Well, a single PCB version of the GTX295 is meant to be on the way, but still a double slot width card as far as I'm aware.
  15. Christopher N. Lew
    23 Apr 2009
    Flexible riser 'cards' for PCIe are quite affordable. Can I mention the supplier? just google for "flexible riser card PCIe"
  16. JackOfAll
    23 Apr 2009
    Might just get away with it for folding. But it'd not sit well with my own rule of trying to run PSU's at 60-80% max of their rated capacity. ;)
  17. saspro
    saspro IT monkey
    23 Apr 2009
  18. Christopher N. Lew
    23 Apr 2009
    Single slot, water cooled GTX285 cards exist (BFG, possibly others), but my pocket isn't deep enough for four, let alone seven. But they make me drool ...
  19. Turbotab
    4 Feb 2009
    IIRC there is a single slot water-cooled GTX 285, a Zotac I think, so there is hope..
  20. Christopher N. Lew
    23 Apr 2009
    Yeah, I liked it. I do have a USB stick with the 8 virgin GPU folders in place, and 8 icons with suitable properties, which I use for initial setups. So far I've not had to upgrade a client ...
