Now use 4 cores in VMware player
Discussion in 'bit-tech Folding Team' started by brooksy, 28 Oct 2009.
  1. brooksy
    brooksy What's a Dremel?
    24 Apr 2009
  2. coolamasta
    coolamasta Folding@Home CC Captain 2010/11/12
    26 Apr 2009
    Cool nice find, thats basically the same mod I use on VMware Workstation to get all 4 cores working, never used to work on Player so must be a new version out or a beta :D
    If you run NotFred then people get on this because you will pop out more points running 1 x SMP-4 instance than you will with 2 x SMP - instances :thumb:
  3. ThunderBob
    ThunderBob What's a Dremel?
    19 Sep 2005
    Looks to be 3.0 Beta. :D
    And just as a question. The person says they use Bal3wolfs VM??
    Looked for info but found very little. Is it like Notfred? or is it used with a VM Ubuntu?
  4. ThunderBob
    19 Sep 2005
    Ok. Tested and confirmed.
    VM Player x2 (2000ppd+1900ppd) on a q6600 with 2 cores on each and both running 1920pt WU.
    VM Player 3.0 Beta x1 (4600ppd) 4 cores on 1920pt WU :)
    700ppd jump. Very nice :D
    Correction 4750ppd for 4cores :thumb:
  5. oatey4519
    oatey4519 can't be arsed...
    5 May 2009
    this looks good..
    well worth the try for a few extra points:D
    downloading now
  6. brooksy
    24 Apr 2009
    A mythbusters confirmed .
    VM Player x2 3770.51 ppd on a q6600
    VM Player 3.0 Beta x4582 ppd
    800ppd increase and the pc is more responsive.:D
    Mike
  7. oatey4519
    5 May 2009
    Now i'm impressed
    you don't need to set the cores up in notepad
    Do it via the VMP
    Running 2 x GPU 8000+ ppd each
    2 x Notfreds on the new version
    New - 4300 ppd each - 4 cores each
    Old - 2714 ppd each - 2 cores each
    and your right Mike my system is still very responsive
    this is looking good & well worth a try
    :rock:
  8. brooksy
    24 Apr 2009
    I still needed to change the memory allocation in notepad as this was greyed out for me?
  9. oatey4519
    5 May 2009
    If you just have the VMP open
    Not folding...
    Highlight your file on left and change info in settings then
    thats the way i did it..:D
  10. chin913
    chin913 忍び So say we all
    26 Apr 2009
    Just wondering do you still have to run them in low priority mode or just leave as normal.I am trying the new VMware-player-3.0.0-203739 and I have set it 2 run on 4 cpu's per vmware as I have 2 running on this
  11. oatey4519
    5 May 2009
    i've left mine on normal at the minute to see how it goes.
  12. ThunderBob
    19 Sep 2005
    It seems to be producing the same PPD on normal......... *fingers crossed*
    The first Q6600 (4600ppd) is running a 3.2 (8x400)
    The second Q6600 (3800ppd) is running at stock 2.4
  13. chin913
    26 Apr 2009
    Well your ppd seem 2 be much higher than mine there as mine is show per core 1870.21 and 2003.48 and thats on a q6700 @stock speed have you changed the memory allocation amount ?
  14. ThunderBob
    19 Sep 2005
    Memory is set to 1.5gb per VM.
  15. Keith_Whi
    Keith_Whi What's a Dremel?
    6 May 2009
    I Have been away for a week and have arrived home to find everthing has been ticking away nicley without hiccup, this 4 core setup sounds really good, but have any issues reared their ugly heads in the last few days?
    If not I'm gonna have it on all by Monday. :thumb:
    Nice find. :rock:
  16. ThunderBob
    19 Sep 2005
    No issues so far.
    All still ticking along at the same PPD
    Q6600@3.2 giving 4500-5000PPD :jawdrop:
    Q6600@2.4 giving 3800-4300PPD :thumb:
    Thats with both the machines also running GPU clients aswell.
  17. Bork_Bork
    Bork_Bork What's a Dremel?
    26 Apr 2009
    Have just swapped to 1 instance with 4 cores, what memory is recommended?
  18. ThunderBob
    19 Sep 2005
    I set mine to 1.5gb and dont have any issues so far
  19. leexgx
    leexgx CPC hang out zone (i Fix pcs i do )
    28 Jun 2006
    never used VM for folding before , is there an preset up notfred VM around that i could use i am ok ish with linux but do not want to get into to many config command lines that i need to type out (linux programmers need to simply there command line based programs)
    i never really ran SMP before found it pointless due to the lack of PPD i got from them 1200 1700 ppd QX6850 3.3ghz and PHonem II 3ghz 1000 1200 ppd,
    but you lot seem to be getting like above 3000PPD min in 4 thread notfred and min 2000 PPD just on dual core notfreds (per notfred 2 threads, 4000 or more 2 notfreds)
    (the i5 is quite inpressive getting 8800 PPD from an I5 750 {1920 workunit})
    could some one just pack there VM up in an rar and send it me ? msn , skype, yahoo
  20. chin913
    26 Apr 2009
    Get the new vmware here http://www.vmware.com/products/player/ you need 2 register an email 1st ...dead easy then download this http://reilly.homeip.net/folding/folding.zip .
    Extract the folding file into a folder ie folding 1 and folding 2 if you run both ,Run the virtual machine and set it up for four cores then run each vmware I have found running 2 of them @ low priority works better than one on this machine .....Giving me around 4800-5200 now .....I am sure with a bit more playing I could get more from it
