Question for Lizard....
Discussion in 'bit-tech Folding Team' started by littlepuppi, 17 Mar 2010.
  1. littlepuppi
    littlepuppi Currently playing MWO and loving it
    26 Apr 2009
    Are you folding on the 980?
    Did intel let you keep it for the cause?
    What sort of PPD is it getting / how hot?
  2. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    Not right now - our best 980X is still burried inside Project Beast at the moment.
    Yes, Intel very rarely collect review samples form CPC/bit-tech.
    Sorry, re answer 1 I can't answer that question right now as I'll haven't had time to get of our 980X's folding yet.
  3. saspro
    saspro IT monkey
    23 Apr 2009
    I like the sound of that. Bagsy on free cpu's (for advanced user review purposes of course)
  4. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    I forget to add, that while I haven't got any of our 980X chips folding right now I did add a pair of Xeon X5680s folding last Friday. These are the 2P-capable workstation/server equivalent of the 980X and are currently running the bigadv client in Fedora 11.
  5. littlepuppi
    26 Apr 2009
    Nice......
    Lizard,
    I have a friend on OCUK who has got the 980X to 5ghz with hyperthreading turned off... When you get a chance can you see if you can achieve this....
    Also (sry to be uninformed in the area but I try to avoid intel) what sort of effect does hyperthreading have on folding, is it significant?
    Although hats off to Intel for leaving you with that beasty, could you call them say it burnt out during review and you need another? :)
    Thanks in advance
  6. saspro
    saspro IT monkey
    23 Apr 2009
    & the tpf & ppd on these is?
  7. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    5GHz with Hyper-Threading disabled :duh:
    You/he needs to read the latest issue of CPC where I can overclocked it to 5GHz with Hyper-Threading enabled :D
    Just over 20 mins a frame, which works out as 53,096ppd.
    In contrast, my pair of W5580s take 24 mins a frame, which works out as 40,898ppd.
  8. littlepuppi
    26 Apr 2009
    OMG that is awesome, CPC hasnt arrived yet, ill check the post when I get in!
    So just to confirum you get 53000 PPD off 1 cpu?!
    That almost makes GPU folding a waste of time!!!
  9. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    Not quite - that's 53k ppd from a pair of Xeons in a dual-processor motherboard.
    Pretty much so yes - especially as a pair of Xeons:
    1. Consume a lot less power than the equivalent ppd from graphics cards...
    2. ... so emit a lot less heat. A 50k ppd graphics card is deeply unpleasant to be in the same room with.
    3. Are a hell of a lot more reliable thanks to server quality components, OSes and ECC registered RAM.
  10. saspro
    saspro IT monkey
    23 Apr 2009
    And also costs a small fortune if you don't get them free from intel
  11. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    (... we should be pleased that Intel is supporting our folding team)
  12. saspro
    saspro IT monkey
    23 Apr 2009
    & your 210k ppd average
  13. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    Is that a little green envy daemon I hear? :) It's all for the team.
  14. saspro
    saspro IT monkey
    23 Apr 2009
    You won't be saying that if I get my rack of blades :baby:
    Having 5 gpus die on me also hurts my ppd
  15. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    True enough, though if you do get some blades up and running it will be a great contribution to the team - especially with those pesky Ruskies closing in on us.
  16. saspro
    saspro IT monkey
    23 Apr 2009
    Job number 1 at my new company will be looking to consolidate 2 racks of servers to 1.
    The blades will need testing
  17. Christopher N. Lew
    Christopher N. Lew Folding in memory of my father
    23 Apr 2009
    Are these in the same Supermicro board that you used for the 5580s? Did you need a BIOS update?
  18. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    No, I didn't want to disturb my trusty W5580s for too long so I just popped out one for a few mins to flash the BIOS on an Intel S5520SC motherboard instead.
    You will need a BIOS update to support the Xeon 5600 series though in all boards (Supermicro emailed me the appropriate BIOS a few weeks back).
  19. littlepuppi
    26 Apr 2009
    You shouldnt be on the forum lizard! You should be looking into getting that 980 folding @ 5ghz with HT!!! tee hee...
    That will help hold off le ruskis!
    Got a 555 BE arriving tommorow for my 2nd folding rig, that will be it then for me but hopefully I can unlock this one to quad as well :)
  20. confusis
    confusis Kiwi-modder
    5 Jan 2006
    By the looks of it we will overtake Overclockers Australia before the russians get us so we will be in spot # 5 for a month or two.
    We need around an extra 520k ppd to hold off the Russians!
