Open Source Home VM Server help and advise
Discussion in 'Software' started by PegasusM, 18 Nov 2013.
  1. PegasusM
    PegasusM Stand back, I'm doing science
    18 Oct 2009
    I'm going to be building a home server soon but I thought I'd post my plan here so you can help me avoid any mistakes and to help others doing something similar.
    The server will sit between my router and my home network and be based on an i3 with 4-8GB RAM and 4TB+ of storage (NAS), there is a Synology NAS on the network that it will be backed up to.
    My plan is for it to:
    run Ubuntu Server as the host OS with Virtualbox running the following VMs-
    • pfsense to act as a router to the rest of the network with a firewall, antivirus, caching and dhcp.
    • freenas to act as a NAS for file sharing and media streaming with NFS for XBMC and DLNA for smart TVs
    • Linux VM (distro?) for bittorrent with deluge, this will be connected to a VPN so that any VPN overhead will not affect the host or networked machine's internet connections.
    What I'm looking for is any amendments to OSs, suggestions for software or additional VMs I might want to run. Alternatively, is there a better/easier way of doing this?
    thanks
  2. saspro
    saspro IT monkey
    23 Apr 2009
    ESXi would make a good host and is free, you lose the ability to log on to it locally but is probably the best
  3. deathtaker27
    deathtaker27 Modder
    17 Apr 2010
    I was going to say same as saspro (damn ninja)
    Go for a VMware box will make it easier
    PegasusM likes this.
  4. PegasusM
    18 Oct 2009
    I'll look into ESXi thanks, what's the advantage of using that over Ubuntu Server? I assume lower resource usage and better VM performance but will that make much difference in this case?
  5. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    ESXi I find alot more intuitive than ubuntu server, easier to partition off resources, backup etc.
  6. saspro
    saspro IT monkey
    23 Apr 2009
    ESXi is designed for virtualisation so less overheads and more stable platform.
    It's also more use knowing it for future jobs etc
  7. Margo Baggins
    28 May 2010
  8. PegasusM
    18 Oct 2009
    awesome, thanks for the advice, I'll definitely give ESXi and unitrends backup a go.
  9. law99
    law99 Custom User Title
    24 Sep 2009
    ESXi is ace. If you go for new AMD FX stuff you can get IOMMU pasthrough also.... alowing you to do as I have done: I have seperate virtualised Ubuntu servers for SQL, Bind DNS. Then a NAS4Free installation with ZFS using passthrough of a PCIe 4 port sata card for RaidZ. And a reluctant IIS webserver as my friend uses IIS so it makes sense to always keep IIS as my dev environment.
    NAS4free plays nice in ESXi, but I found a lot of negative rep for using FreeNAS in ESXi. This despite them being pretty much the same bsd thing.
    With a seperate nas as well as virtualised one, you could set up rsync cron jobs to both and you are in good hands.
  10. koola
    koola Minimodder
    11 Jul 2004
    Highly recommend CentOS and KVM. Easy to manage, automate and backup.
  11. PegasusM
    18 Oct 2009
    I'm a bit confused how the hard drive share will work. If I have a partition of the drive for storing files I would want the NAS4free/freeNAS VM to share this over the network and the bittorrent vm to be able to access it also. Do I need to create a virtual hard disk first and then add it to both VMs and then transfer files to it across the network? Or is there a way to map a partition in the VMs? Also what file system would I use?
  12. saspro
    saspro IT monkey
    23 Apr 2009
    You create a datastore on free space on a drive.
    Then create virtual hdd's on that
    If you want to share data then you use regular sharing as you can't link a HDD to 2 VM's (like you can't plug a physical drive in to 2 real PC's)
  13. PegasusM
    18 Oct 2009
    Thanks that makes sense. Is it then possible to resize the datastore and virtual hdds later?
  14. saspro
    saspro IT monkey
    23 Apr 2009
    Datastores no (well you can but I wouldn't do it)
    virtual HDD's yes.
    You can add datastores and hdd's to servers as you need them later on if you need to
  15. law99
    24 Sep 2009
    What hardware are you (planning on) using for this?
  16. adrock
    adrock Caninus Nervous Rex
    5 Dec 2006
    personally, i don't rate deluge. the UI is great, but i've found it a bit sluggish overall, had memory leak issues with the web client. i use rtorrent+rutorrent although i'll admit it's on a seedbox and i didn't configure it, but it's been much better for me.
    i'd vote for ESXi too, if only because i've been using it at work for 6+ years and if i suggested something else and you had problems i'd feel guilty i couldn't offer any help.
    you can't link a HDD to 2 VMs, but if you want to invest 6 or 7 figures into some enterprise san stuff you can probably get the same effect :)
  17. PegasusM
    18 Oct 2009
    Intel Core i3-540
    Gigabyte GA-H55M-D2H
    8GB DDR3 1600Mhz
    PCIE gigabit network card (not got this yet, any recommendations?)
    Seagate 3TB ST3000DM001 7200rpm
  18. PegasusM
    18 Oct 2009
    I've not used deluge yet, I'll try rtorrent+rutorrent first and see if i like it, thanks.
    ESXi is my first choice now. Yeah that's fine as long as I can setup one on NAS4free and share it with the other :)
  19. law99
    24 Sep 2009
    you can share via the NAS to everything. Just create applicable account and use whatever you choose to do so. NFS or Cifs.
    Ok. (I believe you have no VT d) Yeah so with your hardware you will be limited to giving the virtual NAS its hdds as virtual devices (I'm never sure of the terminology) rather than passing through any controller etc. There is a limit on VMDK of 2tb I think (i think this is done away with now but should feature in plans if you have a 3tb drive). Obviously a nas won't care and you can stripe 3 if you wanted... I wouldn't. But you could.
    NAS4free has some sort of torrent client built in... never used it though.
    Best bet is to use Intel Gigabit cards. Although some realtek stuff plays nice. YOu'd have to look at the one on the board.
    Edit: Other people are probably better to answer these as I don't do this day to day, just a tinkerer.
  20. saspro
    saspro IT monkey
    23 Apr 2009
    Intel NIC's all the way with vmware.
    Multiple NIC's if you can
