Case Mod - In Progress MAMBA 540
Discussion in 'Project Logs' started by DoktorTerror, 1 Mar 2014.
  1. DoktorTerror
    DoktorTerror What's a Dremel?
    7 Feb 2014
    "MAMBA 540" is the name I have given to this new project is not so random.
    MAMBA why I chose the color green acid MB reminded me of the mamba snake for coloring. While 540 is easy to understand because it is derived from the model of the houses of the Corsair.
    SPONSORED by
    HARDWARE
    CPU: i5 4670k
    MB: Gigabyte G1.Sniper Z87
    RAM: Corsair vengeance pro 8Gb 2133MHz
    VGA: Zotac GTX780
    PSU: Corsair AX760
    SSD: ???
    I'm going to create a system of liquid cooling for the CPU and VGA.
    LIQUID COOLING
    Radiator: 2x Alphacool 240 UT60
    CPU: Bitspower Summit EF *
    VGA: Bitspower NGTX780 *
    Reservoir: Bitspower Z-Multi 100 V2 *
    Pump: Alphacool D5 + Top Bitspower S Model * + Cover Pump Bitspower Silver V2 *
    Fittings: Bitspower *
    *: sponsorship
    Note: The rendering does not reflect the chosen hardware but it's just a visual of how it will be 90% of the final result.
  2. DoktorTerror
    7 Feb 2014
    HARDWARE
    Corsair AX760
    i5 4670k
  3. DoktorTerror
    7 Feb 2014
    Zotac GTX780
  4. DoktorTerror
    7 Feb 2014
  5. DoktorTerror
    7 Feb 2014
    Corsair AIR 540
  6. DoktorTerror
    7 Feb 2014
    Case dismantled everything :D
    I tried to install the front fans externally to gain more space for the zone pipes ...... IT WORKS! I will have to give up the dust filter but in return I gained 25mm
    step right to the dremel to prepare the lower zone to host the second 240
  7. DoktorTerror
    7 Feb 2014
    Alphacool NexXxos UT60 240
    I worked on the base to install the second 240
    here is the final result
  8. DoktorTerror
    7 Feb 2014
    sleeving
    painting
  9. DoktorTerror
    7 Feb 2014
    Would like to thank Bitspower for sponsoring this project :D
  10. DoktorTerror
    7 Feb 2014
  11. DoktorTerror
    7 Feb 2014
    waterblock cpu polished :D
    a extreme look but elegant :naughty:
  12. DoktorTerror
    7 Feb 2014
    base for MB complete :)
  13. DoktorTerror
    7 Feb 2014
    pump test
    test parallelism
    prototype wall
  14. Shurika
    Shurika Minimodder
    9 Mar 2012
    That's just fantastic idea of watercooling in this case! I'll watch.
  15. jeckulz
    jeckulz What's a Dremel?
    18 Jan 2011
    Nice work man.
    Subbed.
    Those blocks are gorgeous!
  16. MODZERO
    MODZERO Minimodder
    29 Jun 2011
    I'm loving the direction this is going great work, those Monsta RADs are insane.
    Subbed.
    J.
  17. DoktorTerror
    7 Feb 2014
    I will try to do a bit of hydrographic
  18. TheViscountGodrich
    TheViscountGodrich Wannabe modder.
    12 Apr 2014
    That looks really good.
    Great work.
  19. DoktorTerror
    7 Feb 2014
    thanks ;)
    :blush:
    are not monsta ..... are UT60 :eek:
    thanks :thumb:
  20. DoktorTerror
    7 Feb 2014
    1 test on plexiglass did not go well
    2 tests on spray cap has gone almost perfect
