Case Mod - In Progress ikea renderfarm
Discussion in 'Project Logs' started by greenfarm, 9 Mar 2015.
  1. greenfarm
    greenfarm What's a Dremel?
    6 Mar 2015
    You probably saw this already on the net, but here is another design for Ikea Helmer Renderfarm (for CPU based Vray and Corona rendering). Each case is lasercut from 3mm plexiglas, there are some configuration options, such as the frontplate designs and mini-ITX or mATX capability (under 200mm wide).
    This renderfarm is designed for low wattage i7 processors (S-Series), to reduce the heat, while still powerful enough to render. I tried many different options, and still designing a few more features, such as easy I/O panel access on the side, and maybe a cutout for the custom cpu cooler on the bottom.
    The main idea was to save time and ease of transportation. All plexiglas parts snap together to create one solid case, and can be easily disassembled and shipped separately in a flat envelope. The cost of shipping can be reduced because you can just buy new ikea helmer cabinet at another location (about $50) and assemble all the nodes in 1 day.
    Anyway, I hope you like! Here you can see the project progress:
    [​IMG]]
  2. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    This looks lovely but I daresay it doesn't look practical from a temperature perspective. How does ambient air get in to the CPU cooler when the drawers are closed?
  3. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Drawers never go all the way to the back of the case, there's usually at least an inch clear back there.
  4. HandMadeAndroid
    HandMadeAndroid That's handy.
    18 Feb 2005
    Personally for my needs I'd be after multiple GPUs for rendering. What software uses CPUs?
  5. Jeffinslaw
    Jeffinslaw What's a Dremel?
    26 Jun 2014
    What program do you use for GPU rendering?
    I'm interested in what program(s) OP uses to render with his render farm. Might be something I'm interested in.
    -Jeffinslaw
  6. DBRichard
    DBRichard What's a Dremel?
    6 Apr 2014
    I use Keyshot which is CPU rendering, would love to have a render farm
    Looks awesome BTW, maybe a little too closed to get enough air though
  7. HandMadeAndroid
    18 Feb 2005
    I use cycles render with blender, it's CUDA based so the more GPU the better.
  8. greenfarm
    6 Mar 2015
    This is the latest prototype with front ventilation panels
  9. greenfarm
    6 Mar 2015
    Current config is:
    5 x i7-3770S, 16GB RAM, 64GB SSD, 2x 60mm fans, SFX 300W PSU
    (each node power draw max is ~150W). approx $750 per node.
    Idle temp ~25c, full load ~55-65c (with Noctua NH 9Li low profile cooler)
    6th drawer will be a small 4 x SSD NAS server.
  10. greenfarm
    6 Mar 2015
    I personally use vray and corona-renderer for architectural visualization, GPU rendering still has many limits for big scenes, not enough RAM.
    corona is actually one of the best new render engines, and is only cpu based:
    https://corona-renderer.com/gallery/
    Vray has been industry standard for many years and is also cpu based, they added gpu option recently which still lacks many features.
  11. greenfarm
    6 Mar 2015
    With xspc temp sensor and power switch on front panel:
    GuilleAcoustic likes this.
  12. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Looking like a bought one now! :thumb:
  13. HandMadeAndroid
    18 Feb 2005
    Dam that looks good!
  14. Jeffinslaw
    26 Jun 2014
    I'm really liking these things... I do a lot of work with Cinema 4D and render times kill me. Would be nice to cut those times down. Too bad I don't have the money for one...
    -Jeffinslaw
  15. Jeffinslaw
    26 Jun 2014
  16. greenfarm
    6 Mar 2015
  17. Jeffinslaw
    26 Jun 2014
    Ehh just slap on some more fans :D
    With more rendering power, it would take less time so less time you would have to hear all the fans. The power consumption would even out as well I would assume. Would be fun to do a test with one of the boards.
    -Jeffinslaw
  18. Bygone
    Bygone Minimodder
    15 Apr 2015
    Looking awesome Greenfarm, have you tried considering Water cooling? getting a full size mobo/cpu block and then connecting all drawers to a common radiator solution on either the side og back of furniture?
  19. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    I've already seen this on the web and own the exact same ikea furniture (but mine is red). You did an excellent job there and pushed the work into stratospheric area. You deserved some rep :thumb:
  20. greenfarm
    6 Mar 2015
    LoL good logic, I am actually considering giving this a try with double drawer height, so 3 per helmer :)
