It's a small shop, an ice cream parlour and my wife wants to get music playing (yes we know we need a couple of licences). The space in front of the counter is only about 3.5mx 4.5m so I thought I should be able to run if off some PC 2.1 setup for less than £100. However I can't find any sight of any that would easily wall-mountable. Has anyone spotted any recently? My preference is for white as that in the main colour in the shop. Alternatively I could get these but I'd need to find an amp. Thanks in advance for any help.
Is the budget stretch-able at all? If so, for pure ease, I'd chuck in a Sonos Play:1 in white. If not, is your preference built-in amplification or a separate amp?
It's a small space so almost anything will be able to provide background music, How about these, and just put a shelf up to put them on. Bluetooth and line-in so you're set for any connectivity.
Now these might work http://www.pulse-audio.co.uk/5051259006478.shtml but I need to run the mains cable up to one of them.
The other option might be a soundbar... they are very compact and might be able to be mounted on top of shelves/cupboards out of the way.
Cant recommend these enough http://www.dawsons.co.uk/presonus-eris-e4-5-near-field-active-studio-monitor-pair
