I know the usual window stuff.. But how should I go about adding a logo to the window? I would naturally cut around the side panel, so the logo remains and the window is what is cut out.. But as the case has mesh in the place where i'd put the window, I can't do that. Anyone got ideas how this could be done?
Anyone got any ideas? Could possibly use a dremel to scratch up the areas that i'd want the logo, but I wouldn't really trust myself to do it well!
Get the logo engraved with either a laser or a CNC machine. Other than that using vinyl decals is also a possibility. Or even getting something else cut from plexiglass and glued to the inside. 100s of ways. You would need to be more specific
