Scratch Build – Complete ⭐ ❚❚ [Verticality by Duality92] ❚❚
Discussion in 'Project Logs' started by Duality92, 29 Nov 2016.
  1. Duality92
    Duality92 What's a Dremel?
    25 Feb 2015
    Parts List
    Progress as of 2016-11-29
  2. Duality92
    25 Feb 2015
    So I just got confirmation from AMD that I'll be getting an A10-7890K for the final piece of hardware :)
  3. Duality92
    25 Feb 2015
    All of it's cables are cut at 3 inches already :)
  4. Duality92
    25 Feb 2015
    I redesigned the motherboard tray yesterday as I found that I wouldn't be able to mount the motherboard to the radiator with the layout I had designed previously because of the motherboard mounting. (couldn't access the 140mm fan holes with the motherboard installed). Now I can install the motherboard somewhat easier AFTER fixing it to the radiator.
    Try and figure out what all the cable combs are for :) 32 total wires at the end.
  5. Duality92
    25 Feb 2015
    Here are pictures of my custom case for the HDPlex 160W (new revision). Since it's a PicoPSU style power supply and I didn't want to mount it to the motherboard, this is my solution :)
  6. Duality92
    25 Feb 2015
    Here is an update. I have completed the power supply case, the power supply bracket and the pump bracket. The main thing left to do is finalize the motherboard mount and make a few spacers for various locations to keep things even. Possibly 140mm fan grills too if I have long enough M3 screws.
  7. CroyAlore
    CroyAlore What's a Dremel?
    17 Feb 2017
    I would have never though to build a computer around a radiator, it looks really interesting cant wait for an update.
  8. Duality92
    25 Feb 2015
    So the build isn't dead and I appologize for the lack of updates, I was faced with a big problem, the motherboard I had modded to remove the 24-pin and 4-pin connectors didn't survive the surgery I put it through. I had to order a new motherboard and design a custom PCB to achieve the look I was after
  9. kim
    kim hardware addict
    10 Jan 2016
    very interesting project, but what's on last pic??? I just have a full size black image...only my side?
  10. Duality92
    25 Feb 2015
    Fixed it, it seems it was not resized properly, thus displayed in full resolution lol
  11. Duality92
    25 Feb 2015
    Here is the custom PCB with everything soldered :)
  12. Duality92
    25 Feb 2015
    So here are the final pictures :)
    Not 100% happy with how things turned out to be honest, so there will definetly be a Verticality II eventually!
  13. Cheapskate
    13 May 2007
    It came out awesome. I'd add a clear cover over the power junction you made. I would shock myself on that regularly.
    Verticality II: Integrate cable combs and a larger tube for a reservoir. You could integrate O-ring grooves or add a little silicone glue if you don't trust it. (I missed being in on the planning stage here, and I love throwing out suggestions. -apologies. :D )
  14. Duality92
    25 Feb 2015
    Appreciate the input, round 2 will be quite the event ;)
