Hardware Fractal Design Node 804 Review
Discussion in 'Article Discussion' started by Combatus, 17 Sep 2014.
  1. Combatus
    16 Feb 2009
  2. Maki role
    Maki role Dale you're on a roll... Lover of bit-tech
    9 Jan 2012
    If the Node series cases didn't already look like microwaves, then this one really sorted that out with the window. Put the right hardware in and you may even be able to cook a meal in it.
  3. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Why didn't they put the I/O & switches on the same side as the window? :wallbash:
  4. Anfield
    Anfield Multimodder
    15 Jan 2010
    I guess it is to do with cable management, if you put the cables leading to I/O and switch in the same half of the cube as the window the cables are more visible, as opposed to how it is where they mostly run through the other half that doesn't have a window.
    But yes, it is kind of stupid because you can't really put the right side of the case against a wall or desk without leaving a big gap.
  5. mclean007
    mclean007 Officious Bystander
    22 May 2003
    you're probably right, but a bit of stealthy cable routing and a nice clean conduit/cover could have solved for that.
  6. MightyBenihana
    MightyBenihana Do or do not, there is no try
    8 Sep 2011
    Product design fail 101 - well spotted. I thought the same about the position of the ports and optical drive on the EVGA Hadron.
  7. SuicideNeil
    SuicideNeil What's a Dremel?
    17 Aug 2009
    Hmm, I was thinking it looked like a mini fridge myself, my old flat mate used to have one with a window in the front and it looked almost exactly like this from the outside... :-/
  8. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
  9. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Yes you did. I merely highlighted the error for those who don't have the reading. :thumb:
  10. Anfield
    Anfield Multimodder
    15 Jan 2010
    Yep, looking at it again it is obvious. I guess I was just looking too hard for an explanation as for why they thought putting them on the right side would be a good idea:wallbash:
  11. Xploitedtitan
    Xploitedtitan What's a Dremel?
    23 Sep 2009
    I am using this case for a couple of months now. I didn't plan on using the window, so everything on the right side is very nice for me, the computer being left of my monitor.
    USB ports and power button are in reach.
  12. abezors
    abezors Lurking since '08
    21 Apr 2010
    This case is also ITX compatible, I've just put a Z97i-Plus in mine.
    I'd say it's main strength is for a beefy watercooled ITX rig, as you can get plenty of cooling packed in there and still have plenty of room to fit everything else in, unlike the 304 which is a hell of a squeeze. The main downside I've found is it's weight once filled with WC gear, this isn't a case you'll be hauling to LANs regularly.
    NOTE: It's definitely worth noting that the 60mm maximum radiator depth (on the motherboard side of the case, front mounted) is of course totally dependant on your graphics card length. My 290 is too long, which means I can't fit a fan to my slimline rad on the bottom half - it has one fan on the top half only! Fortunately I have a second 240 rad in the PSU compartment. It's possible a slimline fan will fit in the gap, but their performance on rads is probably not worth the bother.
Tags: Add Tags
