Other install windows on Android?
Discussion in 'Software' started by Podge4, 9 Mar 2013.
  1. Podge4
    Podge4 Oi, whats your game?
    17 Nov 2009
    I realise this may be unlikely but Is it possible to create a virtual windows OS to run on my Tegra 3 Android tablet?
  2. deathtaker27
    deathtaker27 Modder
    17 Apr 2010
    nope, windows is x86 or x64 at its base, Tegra 3 is arm at its base so therefore this is impossible
    Windows RT installation media is not available to the public, and that is the only arm based version of Windows
    I expect there to be some way somewhere of install it and using an emulator but ask yourself, why do you need it so bad?
  3. Nexxo
    23 Oct 2001
    In theory you could install Windows RT on a Tegra 3 tablet. If you can find the installation file.
  4. itrush07
    itrush07 Minimodder
    28 Nov 2007
    Oh, so this thing is really possible.. checking the big 'G' for that file..
  5. Gareth Halfacree
    4 Dec 2007
    It certainly is. There are several QEMU-based x86 emulators available for Android, including this one. Those will let you install almost any x86-based OS onto your tablet or smartphone.
    It won't run *well,* mark you - hardware emulation is always slow - but it will run, contrary to the naysayers.
  6. TheStockBroker
    TheStockBroker Modder
    19 Nov 2009
    Alternatively, 2X for Android is free, easy to set up (and fantastic); and will do whatever you want!
  7. Podge4
    17 Nov 2009
    I was just wondering if were possible, thanks Gareth, i'll look at that. If it doesn't work that well then ok but i'll take a look and see.
