Case Mod - In Progress Akasa Eclipse-62 modding
Discussion in 'Project Logs' started by Rodrigo Vicentini, 16 Jan 2012.
  1. Rodrigo Vicentini
    Rodrigo Vicentini What's a Dremel?
    30 Apr 2006
    Hello friends, I am returning to the world of modding after a long layoff, I have a new project, but with the old design (http://forums.bit-tech.net/showthread.php?t=112068)
    I will work in an Akasa Eclipse-62, which has enough space inside ... and best of all the sides are smooth and have no vent hole to even disturb me
    (my English so bad :duh:: )
    photos speak better than me :lol::lol::lol:
    The Akasa Eclipse-62
    Colour: Smooth black
    Chassis frame: 1.5mm aluminium
    Removable panels: 1.2mm aluminium
    Slide-out motherboard tray: Mirror finish stainless steel
    Motherboard types: ATX & EXT ATX
    5.25'' external bays: 4
    3.5'' removable external bays: 2
    3.5'' removable internal bays : 5
    Fans Two 120x25mm fans (front and rear)
    Fan dimensions: 2 x 12cm fans (front and rear)
    Dust management: Washable air intake filter
    USB ports: 2 at front
    Front PCI slots: 1
    Rear PCI slots: 8
    Dimension 460 x 240 x 560mm (H x W x L)
    disassembling
    bays 5.25" e 3.5"
    frente (esqueci de fechar as bays)
    wheels
    Removable panels
    (one side is losing color:( )
    yet did not make the cut, but the design is ready ... I hope you like... I'll start with the easiest ...
    drawing
    Cutting discs [​IMG]
    Waynio likes this.
  2. Rodrigo Vicentini
    30 Apr 2006
    the cut :thumb:
    but unfinished hehehe
    finished
  3. Darkwisdom
    Darkwisdom Level 99 Retro Nerd
    27 Aug 2011
    Nice design, looks a bit jagged still. Or it needs respraying.
  4. Rodrigo Vicentini
    30 Apr 2006
    tks dute, yes it was iregular, but after sanded and polished, was much better....
  5. Cookie Monster
    Cookie Monster Multimodder
    27 Aug 2003
    I dont know why but I thought that design was going to be on the mobo tray, think that would be possible while keeping the strength to hold the components and any cooling?
    Just an idea.
  6. rchiileea
    rchiileea Minimodder
    11 Jan 2008
    I loved the akasa eclipse when it came out, infact I done this to the front of mine at the time... (whats on the LCD gives you and idea of how long ago this was)
  7. Rodrigo Vicentini
    30 Apr 2006
    for now I will not make changes in the mobo tray, I am preparing for this mod Campus Party Brazil happens now 02/Feb days and will not allow time to change how I wish :wallbash:
    nice work dude, akasa eclipse is a great case :thumb:
    this is the new design I'll do, I'll cut it in the slide panel (behind the mobo)
    let's start cutting...
  8. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    verry nice!
    Love the cut-outs.
  9. Rodrigo Vicentini
    30 Apr 2006
    tks dude :thumb:
    is kind of weird because the court is unfinished, then will get prettier
    this rose to finish this part, to take the burrs
    and here with a R$1 (it has the same size as a 2 euros coin) coin to give some idea of ​​the size of cuts
  10. Rodrigo Vicentini
    30 Apr 2006
    some details of the slide painel
    xMathiasD likes this.
  11. Rodrigo Vicentini
    30 Apr 2006
    I'm looking for pink UV plexiglass, but I'm not having success ... so I decided to try to do my own plexi pink = D
    this is the powdered resin:
    This resin is used in the manufacture of orthodontic appliances ... the colors are lime green and pink UV ... I'll use the pink
    The application process is very fast, as I need the hands free, I did not take photos
    molds:
    is ready, now is cook for 2 hours ...
    some time later ...
  12. Rodrigo Vicentini
    30 Apr 2006
  13. logicmike
    logicmike What's a Dremel?
    23 Jan 2011
    Loving the rose artwork, must have taken ages to cut it all out. what was the tool you were using for the small cut outs.
  14. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    are u kidding me :|
    Daaaaaaaaaaaaaaaaaaamn!
  15. davenoelperkins
    davenoelperkins What's a Dremel?
    5 Dec 2011
    [​IMG][/QUOTE]
    what kind of bit is that?
  16. KidMod-Southpaw
    28 Sep 2010
    I don't know. You could have just told him.... :)
    Anyway, great design, love it!
  17. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Nice artwork. ;)
  18. Roboduck
    Roboduck 01110001 01110101 01100001 01100011
    1 Dec 2009
    Wow, fantastic work! I'm still amazed you "made your own plexi"!
    +rep & Sub'd
    Rodrigo Vicentini likes this.
  19. terrierizer
    terrierizer What's a Dremel?
    8 Sep 2011
    Absolutely stunning piece of work. I like to see new ideas, it's easy to incorperate overs ideas in your own work so my congratulations as I haven't seen this before, well done. :clap::clap::clap:
  20. DJ101010
    DJ101010 What's a Dremel?
    8 Aug 2011
    I am completely blown away by the cut out work! That rose is freakin sweet!
