Core 17 Updated
Discussion in 'bit-tech Folding Team' started by r3loaded, 7 May 2013.
  1. r3loaded
    r3loaded Minimodder
    25 Jul 2010
    Posting this here in case you guys haven't seen it: Core 17 update, video, and reddit live Q&A
    The juicy details:
    • GTX 680 goes up from 30k to 80k PPD
    • Titan goes up from 50k to 120k PPD
    • But most incredibly, 7970 goes from 10k to 110k PPD!! :D
    It's time to bring GPUs (particularly AMD Radeons) back into the fold - even a 7870 will net you 50k on the new core! :clap:
  2. TaRkA DaHl
    TaRkA DaHl Modder
    15 Mar 2011
    Any flags required to pick them up? Or are they just part of the fold?
  3. r3loaded
    r3loaded Minimodder
    25 Jul 2010
    Well it's out of beta now so it should be automatically enabled for GPU slots. Check your system to see if it's being used - if not, advmethods should definitely enable it.
  4. DocJonz
    DocJonz Another CPC refugee .....
    24 Apr 2009
    As I understand it, its still in beta testing at the moment - therefore, you would need to add the beta flag to pick it up. In HFM, you'll see it come up as Core ID '17' and Core 'ZETA'.
    I tried it on my test machine with a GTX 560 - it's not good for Fermi, as the PPD dropped by about 2k - it's really geared for Kepler and Radeon 7xxx's.
  5. Christopher N. Lew
    Christopher N. Lew Folding in memory of my father
    23 Apr 2009
    Well, that's going to make choosing a new graphics card more difficult :sigh:
  6. ross2011
    ross2011 folding for my daughter
    11 Nov 2011
    580 same points
    im running a gtx580 at 920mhz and still getting normal, about 30500ppd 2m11sec tpf totaling 3hours 26mins project 7663
    ross
  7. TaRkA DaHl
    TaRkA DaHl Modder
    15 Mar 2011
    Really is an update for Kepler and other high ends, my GTX460 just picked up a core 17 and is sitting at the same PPD it always has. Enjoy the points big spenders :)
  8. coolamasta
    coolamasta Folding@Home CC Captain 2010/11/12
    26 Apr 2009
    Hmmm interesting, wonder what my heavily overclocked H2O'd GTX670 could pull off on these...
  9. r3loaded
    r3loaded Minimodder
    25 Jul 2010
    It's actually quite easy - Radeon 7970 for most PPD/£, Titan for most PPD/W :D
  10. johnim40
    johnim40 Minimodder
    23 Apr 2009
    my 2 gtx660s are happily running them and running cooler just using 1 core per gpu on my i5 2500k
    and my gtx560ti too on my i5 750
  11. TaRkA DaHl
    TaRkA DaHl Modder
    15 Mar 2011
    What sort of points increase are you seeing on the 660s and 560?
  12. johnim40
    johnim40 Minimodder
    23 Apr 2009
    normally i get 90-100k ppd
    but got 140ppd yesterday
  13. Scorpuk
    Scorpuk Minimodder
    10 Jan 2012
    Hmmmm might get a 7970 and relegate my GTX580 to folding. :)
  14. DocJonz
    24 Apr 2009
    I tried adding the GPU slot under Linux with the v7 client - seemed to work without effort with the new Core.
    (Details: latest patches on Ubuntu 12.04 with GTX 460 and beta flag in v7.3.6 client).
