Scratch Build – In Progress Diy-itx <---High Energy---> with Bitfenix, Dremel & AquaTuning- Nov.20.2013
Discussion in 'Project Logs' started by La carotte d l'o, 18 Oct 2013.
  1. La carotte d l'o
    La carotte d l'o What's a Dremel?
    27 Nov 2007
    Hi
    I am a Finnish fellow, Tuomas Soikkeli
    I have done some mods... Some years ago.
    Some reasons modding wasn't so important to me. And i kind of forget the whole thing.
    Now it tastes good again. :D
    I have started a project.
    I would like to introduce my sponsors:
    Thank you!
    Here is where i started:
    I had made earlier this kind of case:
    It supposed to be very simple, kind of "testbench".
    After looking it couple of days, i noticed that its just lame. :eeek:
    So this project log is telling you how i think it should be looking. :)
    I had only on drive slot, but i wanted to have an optical drive, and a Bitfenix Recon fan controller.
    That was i little problem.
    Lets solve that little issue:
    Here's the Recon:
    I love it. :)
    Still i wanted to tear it to pieces:
    :duh:
    I made some metal work with Dremel:
    Simple stuff..
    Then i did some cuts for the Recon's frame too:
    Aha! Now you might get the idea:
    Here's the measures in millimeters,
    for the support plate for the lcd. If you wanna avoid your warranty too. :D
    My plans for the frame..
    Somehow, it looks better in the plate. :sigh:
    Some Dremeling and drilling later:
    And after bending:
    And some test fitting:
    Now i have a frame for my thingy.
    Then i needed some cables, used old ide-cable to do some wiring.
    Soldered cable to the lcd screen:
    And for connecting the touch panel, i used these:
    Led-switch cables taken for the Bitfenix Spectre led fans.
    Soldered them:
    Also lcd's backlight needed to be connected:
    Everything fits inside the face plate:
    Looks nice. :)
    Did some modifying to the board to get it little smaller, an attached it to the frame.
    Then it was time to make hinges:
    Couple of these.
    One this kind of thing:
    And after many tries i got things working as i wanted:
    Welded the hinges for the lcd's support plate:
    And here it is.
    Closed:
    And open:
    More Dremeling:
    And, after bending and welding the frame started to be ready:
    Again, everything fits nicely:
    Then i had loads of soldering to do:
    Wires for the backlight:
    And the lcd:
    I twisted the pcb-board to get the fan connectors etc, in better place.
    So, wiring had to be twisted too.
    Everything connected:
    Power cables:
    And testing:
    And with the fans and temperature sensors connected:
    Everything works as supposed.
    Im happy. :)
    To be continued...
    GuilleAcoustic likes this.
  2. _0CooL_
    _0CooL_ What's a Dremel?
    12 Jul 2013
    wonderfull idea. what type of welding for metallic parts ?
  3. Boorach
    Boorach Minimodder
    16 Feb 2013
    Great idea executed very nicely. With work of this standard this build should be something special.
  4. La carotte d l'o
    27 Nov 2007
    Thank you!
    I use Kemppi MLS3000 Tig-welder for all welding.
    Thank you. I hope it will. :)
  5. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    That's F***ing gr88888t mate ! Absolutly awesome idea and building. Having the idea is one thing, but being also able to build it is pure talent (+rep and 5 well-deserved stars to you).
    I'll follow this with great attention.
  6. Sn00k3r
    Sn00k3r What's a Dremel?
    7 Apr 2011
    great Idea with that panel-drive-combo, i will follow this..! :D
    subbd :cooldude:
  7. LegendaryScott
    LegendaryScott Trying to live up to the name
    5 Apr 2013
    skilfully done
    hope to see more skills like this in the rest of the build
    Great start
    ...and
    Subbed
  8. La carotte d l'o
    27 Nov 2007
    Thanks mates for the feedback! :)
    For the next update you might can watch some video:
    ^ There's one of our youngsters doing some 3running
  9. Cheapskate
    13 May 2007
    Good to see you at it again.:D
    That mod is really clever.
    As for the kid, he seems to understand you can't jump off a 2 story building and land on your feet. -That's a good thing.
  10. Darkened
    Darkened Minimodder
    28 Feb 2004
    Hey Tuomas,
    It's really really and I do mean really cool to see you back.
    I've always thought your skill-set and abilities as a modder are pretty much beyond approach, so I'll be following this for sure.
    A fellow modder from Finland,
    Darkened
  11. La carotte d l'o
    27 Nov 2007
    Thanks Cheaps. Yeah, its a good thing. Allthought he has a little brother who haven't understand that. ( if my memory doesn't fail.. he has over 60 stitches.. :) )
    Thanks Darkened.
    Nice words from you, allmost makes me blush. :D
    Update
    Case needs feets.
    And when case has named like this one..
    I thought that feets has to have size... and size is what matters. :sigh:
    First i welded together four 6mm thick plates. Then i drilled some holes.
    Then it was a time to do some machining.. Milling with manual thing to be precise..
    looking this kind of pictures is.. So boring..
    Lets jump over that part and look finished parts for the feets:
    :thumb:
    Some countersuncking.. (or how it should be written)
    Then i needed some little parts, first i drilled them all. After that i cutted them of with dremel.
    Little parts done..
    After welding parts together, some sanding and little polishing..
    And there we have rough enough feets for the case.
    But those ain't done yet.. But lets continue with them later.
    Thanks for watching
    Hope you liked!
  12. Cheapskate
    13 May 2007
    :jawdrop:
    Yeah, That's what I remember about you.:D
  13. Darkened
    Darkened Minimodder
    28 Feb 2004
    My own point proven not two hours after writing it :hehe:
    Darkened
  14. La carotte d l'o
    27 Nov 2007
    Thanks mates. :)
    Update
    First i did some cuts and openings for the case.
    Those will be needed later.
    Then it was time to remove that ugly green paint.
    I wonder what iwas thinking about in first place..
    Sandplasting in outdoors.. Hmm. i wonder who is going to clean that mess. :eeek:
    And after that.
    Much better.. :)
    Case will be powdercoated later..
    Thanks for watching. I hope you like it.
  15. Ace_finland
    Ace_finland Minimodder
    11 Aug 2012
    What a great build and attention to detail! Nice with another finnish modder :)
  16. Mechh69
    Mechh69 I think we can make that fit
    16 Sep 2009
    Love the innovation so far, taking a IDE cable and soldiering it to a new display is impressive especially with the hidden drive above it.
    As I have told everyone in the past don't worry about the English we will figure it out by the pictures and google translate if we have to.
    Great progress and I am subbed.
    Mechh69
  17. longyny
    longyny What's a Dremel?
    8 Aug 2012
    I love it!!
    I envy you, soldering it's imposible for me...
    I will keep here to see how this ends.
  18. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    yay he's back! :D I love your work dude, looking forward to seeing how this moves on :D
  19. La carotte d l'o
    27 Nov 2007
    Kiitos!
    Thanks. It seems that here you can find more finnish modders than any fiinnsih site. :D
    Thanks mate.
    Actually it wasn't so hard at all. Thanks mate.
    Good to be back. Hope you enjoy.
    Now its good time to look what:
    Send me.
    These will be modified later..
    Loads of Cables and some fans..
    Everything what i needed.
    And a Recon. Wich you have already seen.
    Cables will be mixed in this way:
    More of that will be seen later. :thumb:
  20. La carotte d l'o
    27 Nov 2007
    Update (some kinf of)
    I had a couble days possibility to use milling machine.
    So i decided to use it as much i can.
    After that i have to do rest of the parts using hand tools.
    In these days its not so easy for me than it was earlier.
    I have a disease that have taken some of my prestidigitation.
    But i think i can handle with it. :)
    So... Lets go.
    I marked guidelines for milling, and placements for drilling.
    Driller some holes..
    And learned for the first time...
    It saves hours if you cut of the extra material with corner grinder,
    than take it off with the milling machine.
    Ooh, how stupid man can be sometimes. :D
    And again some boring milling pictures...
    And finally machined parts..
    Loads of sanding to do to get those shiny..
    Then i used my genius pressing tool.. -Brutal forcing machine- indeed
    A mold, sheet of acid proof steel, and finally over 20 tons of weight..
    And you can get a cup..
    Some cuts..
    And making a hole with Dremel and rotary file.
    And theres a hole..
    Part isn't done yet.. What those are, and where they are going. Again ill show you later.
    ^ Sorry :D
    Here's the Motherboard i will use..
    These antennas will be modified to day.. Those are ugly as hell like that.
    So more coming in this evening.
    Thanks for watching and Have a nice day!
    And finally..
    I would like to thank Dremel for their support.
