Case Mod - In Progress Project: Iron Man Parvum - Updated 8/04/2015
Discussion in 'Project Logs' started by Dan Woods PC Mods, 19 Mar 2015.
  1. Dan Woods PC Mods
    Dan Woods PC Mods What's a Dremel?
    15 Mar 2015
    This project started because I just love Iron Man, its going to be a great color scene and I am going to have a lot of fun build it.
    The Plan so far is to have a mini arc reactor 3D print for the front which is being done as we speak and maybe some airbrushing on the top, back and front.
    Case: Custom Parvum S2.0
    Motherboard: Asus Maximus VII Gene
    CPU: Intel i7 4790K
    GPU: Asus Ares III
    Memory: Avexir custom made one of a kind Iron Man 16gb 1600mhz
    SSD: 4 x Samsung Evo 840 250GB
    PSU: Cooler Master v1200 Platium
    WATER COOLING
    All up in the air at the moment, plan on using all gold with red coolant. I keep on seeing pictures of this new amazing gold range that Bitspower has got but can not find anywhere to buy it, I will have to email them in regards to this one.​
    Well every project has to have a start and mine starts right at the beginning under Parvums CNC router.
    Here are an amazing set of shots that Justin from Parvum was nice enough to take for me.
    It's reserve ATX, wider and longer to fit my Ares 3 better and has a huge window in the top.​
  2. Throbin Hood
    Throbin Hood What's a Dremel?
    18 Mar 2015
    Love Parvum, Look forward to seeing what this becomes.
  3. storm-83
    storm-83 Minimodder
    7 Nov 2014
    Hope you get your hands on some gold fittings - 'cause that color combo with red coolant sure would be an interesting one!
  4. Hukkel
    Hukkel James' minion
    20 Dec 2012
    I love how Parvum helps out people to make custom design cases.
    Looking forward to this.
  5. MODZERO
    MODZERO Minimodder
    29 Jun 2011
    The colors look spot on, this will be good. What are you cooling plans? on water with lots of gold?
    J.
  6. Dan Woods PC Mods
    15 Mar 2015
    Your not the only one, I normaly to for a color theme so this is a bit different for me aswell.
    I will be getting a hold of them fittings as soon as I can.
    This is the res I plan on using.
    Yeah the guys at parvum are amazing and always up to help with any custom design.
    I plan to use gold fittings and red coolant.
  7. Dan Woods PC Mods
    15 Mar 2015
    Little Teaser shot for everyone of things to come.
  8. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    Subbed, love Parvum stuff! Gold seems to be the hip thing lately.
  9. Dan Woods PC Mods
    15 Mar 2015
    Iron Man Parvum is here and this is how it was built.
    Time to start adding some hardware and getting some more photos tomorrow.
    What does everyone think.
  10. Guest-768813
    Guest-768813 Guest
    looking nice!!!!!!!!!!!!!
  11. storm-83
    storm-83 Minimodder
    7 Nov 2014
    Saweeeet!
    I'm all in for the colors :thumb:
  12. Dan Woods PC Mods
    15 Mar 2015
    I actually have 2 Iron man Parvums, One Mark 3 and one Mark 42.
    Here is a crappy camera phone photo.
  13. Dan Woods PC Mods
    15 Mar 2015
    Small update!!!
    Got some new gear for the Iron Man build,
    Asus Ares III
    EK-Supremacy EVO - Gold
    Do you think I should make the black frame red or gold, I will be using pastel red.
    Here is what you are all here for the pretty pictures, as you can see I dropped the light tent and went back to taking photos in nice places, this one is my garden.
  14. Dan Woods PC Mods
    15 Mar 2015
    Thanks for all the nice replies everyone.
    So a quick update I had a mini arc reactor 3D print and this is how it turned out, its not mounted yet as I am not 100% sure about it.
  15. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    I think it looks a bit rough, but it's kinda hard to tell from a pic that size. Is that the finished reactor, or is there still sanding / finishing work to be done on it?
  16. MODZERO
    MODZERO Minimodder
    29 Jun 2011
    Case is looking great, I think you can do better with the arc reactor. You've missed a trick really, talk to the parvum guys about having one cut, they could use the two front panel layers to add depth to the reactor and cut you a third/forth layer to add to the front. it could be a 120mm fan grill of sorts.
    J.
  17. Dan Woods PC Mods
    15 Mar 2015
    Yeah I was not 100% sold on the arc reactor but I am wiring up some LEDs now so will see how it looks.
  18. Dan Woods PC Mods
    15 Mar 2015
    So the Mini Arc Reactor is coming along very well.
    Took me a couple of hours to wiring up all these LED's but I have to say I am very happy with the outcome.
    What do you guys think does the lighting look good.
    Here is a little Teaser photo with more details to come.
  19. Dan Woods PC Mods
    15 Mar 2015
    So this is how I made the Mini Arc Reactor glow, 14 LEDs wired up and they are very even.
    The LEDs are wired in banks of 4 and a bank of 2, which means only the bank of 2 needed a resister.
    This is going to look great in the front of the Iron Man Parvum.
  20. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    That looks sweet, nice job!
