Hey, I'm kinda in over my head here, but I need to be able to do this myself. I have a water cooling system for my CPU, and it desperately needs a good drain, flush and clean. It is a XSPC branded system with pump, radiator & reservoir. After doing some research, apparently de-ionised water is fine for flushing and washing, but I was hoping to reuse the actual fluid although it has sediment in it. Would sieving the fluid through a tea-strainer work? (As you have probably already guessed, I'm a novice). Also, toothbrush? Any advice would be appreciated. CCA
I picked up some deionised water to flush the system with. Coolant wise I've ordered this: XSPC EC6 Coolant. Also ordered this Mayhems Blitz Basic Cleaning System.
