Just a quickie - as the title says, is a 750W PSU enough to run 2 670s overclocked in SLI, plus an overclocked 2500K and all the rest of the usual system gubbins? Conflicting evidence on the tubes suggests min 700W or min 850W, so bit wide-ranging.
Overkill in truth my own system with 2 680s draws only between 400-480 from the wall ( i7 950 CPU overclocked to 4ghz) sandybridge is more power efficient so you should see less.
Yeah - with my rig (OC'd 4770K and SLI 780s) I have this (read using a power monitor thing) Idle - 100W 100% CPU only (just Prime95) - 230W 100% GPU only (just Furmark) - 670W 100% CPU and 100% GPU (Prime 95 and Furmark) - 760W So you'd be fine
Assuming a good quality PSU with a strong 12v rail you will be fine. I used to run overclocked Asus DCII 670's in SLI on my ToughpowerXT 675w PSU without a single issue.
These are actually the ones I'm going to be running, so good to know - thanks. Cheers to all, guys. Appreciate the assistance. I've ordered a 750W XFX XXX edition as didn't see the point paying an extra £20 for the Black edition. Heard some tales about fan noise so will see how that goes ("play it by ear", in effect? Sorry...had to...).
