Electronics Help With Timed Relay
Discussion in 'Modding' started by BagUd, 16 Apr 2012.
  1. BagUd
    BagUd What's a Dremel?
    5 Jan 2004
    Hi guys. I’m trying to design a circuit that will activate a relay for 1-2 seconds. The relay must first be activated when I release the button not when I push the button. I’ve been trying with some capacitors and diodes, but can’t seem to get it right. Either way I’m stuck at the moment.
    It's for 12V DC.
    All help is appreciated.
  2. Nealieboyee
    Nealieboyee Packaging Master!
    14 Aug 2009
    I would use a logic circuit with gates or a latch or some sort, which then feeds a 555 timer circuit.
    Trying to find something....
  3. BagUd
    5 Jan 2004
    I've thoght about a 555 timer chip. but it's over 10 years since i played with electronics.
