Case Mod - In Progress PlayDoh Silverstone TJ 07 update 30.03.2014 with acrylic pipe
Discussion in 'Project Logs' started by arg-ist, 9 Feb 2014.
  1. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    PlayDoh Silverstone TJ07
    Anew worklog:
    At this worklog ı use my old Silverstone TJ07. I call it as PlayDoh of the cases.I want to make 3 different cases from this case.
    First worklog TJ07 V1
    What I want to achieve are:
    To combine front panel with the side window.
    To install liquid cooling and achieving this via acrylic pipe.
    To use a special distributor for water distribution as midplate.
    To enlarge the case for radiators since it is not wide enough.
    To stick some parts into the case to obtain a dynamic view
    first 5.25 rotated
    made a window at middileplate for water distributor
    two 80 mm fan holes are used for pump and tops
    The tops mounted on an alu plate
    and the plate with tops mounted to the case
    The pumps with modkit are sticked to the backpanel
    OTHER WORKLOGS
    SAK SAK 900 D CASE
    http://forums.bit-tech.net/showthread.php?t=271227
    JUMBO CASE
    http://forums.bit-tech.net/showthread.php?t=266554
    TERMINATOR CASE
    http://forums.bit-tech.net/showthread.php?t=267028
    12 Angry Men 900 D Case
    http://forums.bit-tech.net/showthread.php?t=266585
    mmt 900D Case
    http://forums.bit-tech.net/showthread.php?t=266954
    ER36PO Level 10 GT - Acrylic tubing
    http://forums.bit-tech.net/showthread.php?t=269227
    How to make BENCH CASE from an old ATX
    http://forums.bit-tech.net/showthread.php?t=277334
    self made COSMOS II Clear Panel
    http://forums.bit-tech.net/showthread.php?t=277478
    Graphic Equaliser Display
    http://forums.bit-tech.net/showthread.php?t=277610
  2. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    To mount PSU ı made a window at the top.
    Made a mounting kit to mount psu.
    To cover the hole spaces around MB made these parts with gromets.
    made 2 X360 Rad stands for rad mounting
  3. AlienwareAndy
    AlienwareAndy What's a Dremel?
    7 Dec 2009
    Liking it so far.
  4. Wonky
    Wonky What's a Dremel?
    7 Jan 2014
    Pretty unique and interesting PSU placement :clap:
    Intrigued as to how this will turn out now, can't wait for more :)
  5. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    First meeting with acrylic pipes. I had worked before with glass pipes and Copper pipes.
    But Acrylic was differnt. First experiments -how to measure -
    Some tools to work. A plastic mieter box , a handsaw, and a file for the ends.
    and some experiments to bend
    İt was easy to bend L parts, but U and S parts was difficult.
    Therefore I made m y bending table.
    I can bend with different Radius and bend in 2 and 3 directions
    and first experiments with acrylic pipes.
  6. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    I want to make a waterdistrubutor to this place as midplate
    Drawn at corel
    You have two ways to cut plexis
    With CNC Router
    or with CNC Laser
    I used CNC laser
    acrylic sheets from bottom to top.
    No 1: 5mm milk White
    No:2 10mm clear
    No: 3 5mm clear
    No: 4 2mm milk white
    bonding acrylic sheets with cloroform.
    dont use bits for metal use bits for wood..
  7. dietje1908
    dietje1908 What's a Dremel?
    12 Jan 2009
    look amazing !
  8. DoktorTerror
    DoktorTerror What's a Dremel?
    7 Feb 2014
    The last picture is gorgeous :thumb:
  9. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    Fans were taken out to enlarge the case for 2x Thermochill 360 rads
    I made a radiator shroud for fans and used a phobya 3x rad. Gril.
    This was applied on the back cover.
    Covered view of the case.
  10. AlienwareAndy
    7 Dec 2009
    Really starting to look like something now. Nice work man.
  11. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    Back cover painted and finished.
    Made a plexi cover for 5.25, that ı not use.,with flash shining theme. illuminated with led.
  12. Hukkel
    Hukkel James' minion
    20 Dec 2012
    I never thought a routing midplate could be created that easy.
  13. jamsand
    jamsand Minimodder
    21 May 2011
    Aw I thought it was going to be all red and yellow and green
  14. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    another laser cut midplate that ı made for my friend elenorth.
    it has a simple waterway and a silver mirror plexi as ground .and from side illuminated
    and mounted to the case.
  15. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    okey friend added some colors to the case...
  16. DarkSable
    DarkSable What's a Dremel?
    24 Nov 2012
    Love the design, and what you're doing with the power supply - especially contrasted with the bolts on the front.
    My only thing is those pumps... You don't have them even remotely close to decoupled - they're bolted straight into the case. That's about the worst case (no sorry, they also don't even have the benefit of the case around them to silence pump noise) - that is the worst possible scenario for noise that could happen.
    All the noise the pump motor itself makes has absolutely nothing to dampen the sound, and all the vibrations it makes (especially from being suspended from one cross-section) is going to go straight into the case using it as a reverberating chamber.
    Coming from the perspective of someone who sees one of the major benefits of water-cooling as its silence, this seems just painful...
    Do you have any way of silencing it, or is noise just simply not an issue at all? It's just that it would be a shame to have such a beautiful rig not be on display, but if it is on display, it'd scare off admirers. :p
  17. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    You know friend , pumps and tops are mounted on a separate plate. Therefore it is not difficult to isolate this plate with a silikon gasket.
    And ı have no sound problems with my swiftech 655 pumps.
    You said …. Coming from the perspective of someone who sees one of the major benefits of water-cooling as its silence, this seems just painful...
    I agree with you … I have never tried to make silent PC with active cooled radiators., 10-15 fanns, 2 pumps .But ı cann think it with a passive radiator .
  18. DarkSable
    24 Nov 2012
    ^Ahh, that makes a bit more sense.
    I'm just particularly sensitive to noise, though I find using a pair of 140mm noctuas on each of my radiators is perfectly quiet.
    I was just asking because I've worked with those pumps before, and have seen vibration issues from them. It might just be that mine weren't quite as well calibrated.
  19. Wonky
    7 Jan 2014
    Agreed! :thumb:
    Very unusual placement but works well with the design i think.
    Loving how it's turned out, good job dude! :clap:
  20. jojoharalds
    jojoharalds Minimodder
    30 Apr 2014
    This is freakin amazing (great work)like the pump placement .
