Hi everyone. I not new to the Community but this is my first project log that i share. I am Joremos and i want to share my project with you I have been building my first watercooled pc in the late 90´s based on the Lian Li PC70. As big fan from Elite I was really ecited as i heard they will come an new Elite game. I played the first Elite in the 80´s and i liked it. Here are the first pictures what i have done already and what i will do next. Planned hardware Case : Corsair 900D "already have" Mainboard: Asus Crosshair V Formula Z "already have" CPU: AMD FX8320 "already have" RAM: 16 GBG.Skill RipJawsX "already have" GPU: Radeon R9 280X "already have" Power supply : 860 Watt Corsair AXi Fans: Corsair Air Series SP120 Watercooling componets: CPU-cooler: EK-Supremacy Clean CSQ Pump: 2x EK-D5 PWM Motor Reservoir: 2x EK-D5 X-RES 200 CSQ - Acetal Radiator: 2x EK-CoolStream RAD XTX (480), 1x EK-CoolStream RAD XTX (240) GPU-Kühler: HEATKILLER GPU-X³ R9 280X Fitting: Bitspower 16/10 15xBitspower Black Sparkle Rotary 90-Degree, 1xBlack Sparkle Q-Rotary IG1/4"X3 Extender, 2xBitspower Direct-Connect Set 1/4 Zoll, 2xBlack Sparkle Mini Valve With Black Handle Tube: EK-HD Tube 12/16mm Controll: Aquaero 6 What i want to do! The outside is for the new Elite Dangerous game and the complete inside will be an tribute to the original Elite game from the 80´s. First i planed an new top panel with Elite logo as fan grills. Top panel planing Top panel mounted The other thing is to remove the original bottom side panel on both sides and create one with Elite Logo. Side panel Next step for me is the paint job for the in and outside. This one come on the right side and the cobra will be a litle bit greter. The rest of the case will fit to the picture. The inside will be painted like the old c64 version of the game. Black with small white dots and some ship models. Like the Cobra 22.07.14 Small update Here is the link to the gallery with all pictures for all who want to see more picturtes http://www.abload.de/gallery.php?key=q6w4cnGV The next update will take a while because the paint job is a lot of work Regards Joremos
Small update Hi again, the airbrush need more time as i expected :-( But here are some new pictures Regards Joremos
Update 05.09.2014 First some bad news. I have to by an new washing machine because my old one is broken and i must spend my project money into an new one. So i must wait before i can buy the watercooling parts But here some new pictures from my last work and i hope you enjoy it Here some pictures from the finished airbrush on the case front Then i installed the midplate,motherboardtray cover and the backplate. All plates are airbrushed with white uv colour Here is the midplate with the ship models. These are also painted with uv colour. I changed the silver front and back from the Aquaero. I think it looks much better then the silver one Then i sleeved the the cables with black/white sleeve The last one is the holder for the pump and reservoir. That will be installed on the hdd cage Regards Joremos
Hi, its just an small update this time. The first LED test. and this ist the pump holder regards Marco
Back again Hi again, here im back again after a "short" break and here are some ppictures from the watercooling parts. Joremos
Sorry for the delay but here are the pictures from the finished project. I hope you like it. Regard Joremos
