Hi All, which Rainmeter skin are you all using? I am going to attempt to set it up later on today and would be interested in seeing what you all have done.... Thanks Long
i've been using rainmeter for a long time. here's one of my configs i copied the basics from other configs on the dock on the left, the others i made.
Try Samurize it's better imo. Easier to modify, more customizable. I wanted just a very simple looking desktop. Config is wip. http://forums.bit-tech.net/showpost.php?p=2704155&postcount=10740
I agree, it is definitely much easier to customize. Not sure if it is better or not yet though in my opinion. Have a browse through the skins on DeviantArt. There are lots of pretty awesome ones.
I actually use the default skin (enigma), the small monitoring icons look fantastic with a wallpaper like this: http://browse.deviantart.com/customization/?q=organic#/d2ohbo6 The grey one, I'll upload a picture after.
