Build Advice Is it me or...
Discussion in 'Hardware' started by neil_b, 25 May 2011.
  1. neil_b
    neil_b Minimodder
    20 Jun 2009
    Is it me, or are SATA power connectors really hard to push on to the plugs on the storage devices, or are they really meant to that tight????
  2. jasonst888
    jasonst888 What's a Dremel?
    24 May 2011
    They often can be a little tough, just make sure you have it straight on, simple thing I know, which you are probs doing but worth mentioning. Generally I abide by the rule if the cable doesn't want to go on, don't force it! Rather dbl check all is gd first! but sata power cables have always been the exception...:idea:
  3. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    Never noticed that they're really tight, but I guess they have to be otherwise they'd probably always fall out lol
  4. Kakeshoma
    Kakeshoma What's a Dremel?
    11 Jan 2011
    It varies how far you can push the power connector in, but I havent had any SATA connectors that was difficult to get in place.
    Careful so you dont break anything, and get the notch on the right side :)
  5. Pete J
    Pete J Employed scum
    28 Sep 2009
    It should definitely be firm but as all ready said, make sure you're putting it in the right way.
  6. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Heh, tight...
    (sorry)
  7. shah
    shah Minimodder
    29 Jan 2010
    :hehe:
  8. GregTheRotter
    GregTheRotter Minimodder
    9 Aug 2008
    If all else fails, lube that puppy up and have another bash :D
  9. noizdaemon666
    15 Jun 2010
    If all else fails, lube it up and stick it in the VGA port (ask your computer nicely first) :D
  10. Pete J
    28 Sep 2009
    Heh, reread my post and see what you mean! I pride myself on having a dirty mind and yet totally missed it - am I finally growing up? :eeek:
  11. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    Remember, if it don't fit, don't force it...
  12. Kakeshoma
    11 Jan 2011
    Hehe I know, I had to do that do, many words to take the wrong way...
    Hard, tight, fit, push... >>
  13. shah
    shah Minimodder
    29 Jan 2010
    You are not the only one!!! Try to read the thread again, it is jokes :hehe:
  14. murraynt
    murraynt Modder
    6 Jun 2009
    I always find it's harder to pull out. Always have to wriggle it.
  15. Pete J
    28 Sep 2009
    Personally I hate it when it bends the wrong way and you have to twist it upside down. If you have stubby fingers it can be very awkward to manoeuvre into the correct position. Sometimes you just have to give in and flip the mounting.
  16. Telltale Boy
    Telltale Boy Designated CPC Jetwhore
    3 May 2010
    Sounds painful. :naughty:
    Just carrying on the current innuendo of the thread for continuity... ofcourse.
  17. shah
    shah Minimodder
    29 Jan 2010
    This should improve with practise :D
  18. bdigital
    bdigital Is re-building his PC again
    10 Aug 2010
    spit on it if its dry.
    classic
    David likes this.
  19. David
    7 Apr 2009
    :hehe::hehe::hehe:
    +rep
