Hi, I want to fit an SAPPHIRE Radeon HD 7750 Low Profile Video Card in a hec ITX ITX200 case. With some modding would the video card fit. I'm thinking off taking the bracket off and cut out some holes for the ports.
At least show us your setup to see what space you have to play with, can get a flexible expansion card and mount it somewhere inside if space allows
Can you mod, move your PSU near to audio jack? cut those barrier next to psu If i'm using half profile gpu that have card length less than 17cm, i can make it fit that case.
remove the cd drive tray and hard drive caddy, move the powersupply to the former disc drive location over and you'll have the possibility of ~four pci half height slots with space above the psu for your hard drives.
