Other Unigene Heaven 4.0 is here!
Discussion in 'Hardware' started by Stu @ MSD, 13 Feb 2013.
  1. Stu @ MSD
    Stu @ MSD What's a Dremel?
    6 Feb 2012
  2. kirk46
    kirk46 Cheesecake Nom Nom
    9 Jun 2012
    GTX680 all setting maxed
  3. Kernel
    Kernel Likes cheese
    29 Sep 2003
    My lowly 6950 unlocked to a 6970.
    Forgot to screen shot tho.
    Code:
    Unigine Heaven Benchmark 4.0
    FPS:
    19.6
    Score:
    495
    Min FPS:
    5.7
    Max FPS:
    46.0
    System
    Platform:
    Windows 7 (build 7601, Service Pack 1) 64bit
    CPU model:
    Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz (1600MHz) x4
    GPU model:
    AMD Radeon HD 6900 Series 9.12.0.0
    Settings
    Render:
    Direct3D11
    Mode:
    1920x1080 8xAA fullscreen
    Preset
    Custom
    Quality
    Ultra
    Tessellation:
    Extreme
    Powered by UNIGINE Engine
    Unigine Corp. © 2005-2013
  4. MrDomRocks
    MrDomRocks Modder
    5 Sep 2011
    Completely stock GTX570. Tried to overclock once before but doesn't like it.
  5. Sentinel-R1
    Sentinel-R1 Chaircrew
    13 Oct 2010
    Not bad for nearly 2 year old cards :)
  6. The_Crapman
    5 Dec 2011
    Sig rig, all at stock
  7. Stu @ MSD
    6 Feb 2012
    Scaling is poor, going to try with 1 & 2 GPU's
  8. Stu @ MSD
    6 Feb 2012
    Much better with 2x GPU's
    1x 7970 @ 1225/1700
    2x 7970 @ 1225/1700
  9. legoman
    legoman breaker of things
    28 Feb 2010
    i cant force mine to stay on that resolution :(
  10. sandys
    sandys Multimodder
    26 Mar 2006
    Ah Go on then, maxxed 680.
  11. Pookeyhead
    30 Jan 2004
    2x670s @ 1280MHz, 3560 RAM
  12. damien c
    damien c Mad FPS Gamer
    31 Aug 2010
    My scores
    Stock
    OC'd
  13. Guest-44432
    Guest-44432 Guest
    CPU @ 4.7GHz GPU's @ 1050/1575 (Voltage lock down on XFX 7970's...:()
    ↓ Very close scores between us running a similar setup. (If only I could get the voltage unlocked to clock the nuts of these 7970's (BTW it's not a MSI Afterburner problem, it's XFX who have locked the voltages...)).
    Pookeyhead likes this.
  14. Pookeyhead
    30 Jan 2004
    Nope.. very close.
  15. kenco_uk
    28 Nov 2003
  16. mikemaher205
    mikemaher205 What's a Dremel?
    14 Aug 2011
    All at stock clock speeds. :) Now to master OC'ing my new GPU...
  17. MrDomRocks
    MrDomRocks Modder
    5 Sep 2011
    Played with EVGA Precision. OC'd to that of stock 580 as I don't want to push too hard or increase voltage at all.
    Minimum FPS jumped a small amount but max shot right up. Now will this run BF3 ok. I did this before but wasn't stable.
    Dropped the OC as Bad Company 2 white screened and forced me to restart my system.
  18. Guest-44432
    Guest-44432 Guest
    CPU @ 4.7GHz with HT
    3x GTX 670's GPU's @ 1280MHz Core - 7012MHz Memory
    Looks like Tri SLI stomps on Tri fire. :D
  19. damien c
    31 Aug 2010
    Good result there for you TG.
    Around 800 points higher than I got with my Dual SLI 680's OC'd to there max on air, will be interesting to see where they will go under water.
  20. dead beat
    dead beat Rippin six 4 life
    15 Feb 2009
    Exactly the same I'm afraid. Temps will be a little lower is all.
    Having said that, I recently modded the BIOS on my 680's to raise the max voltage, which did allow me to squeeze a little bit more out of them. Temps were barely affected, though that might not be the same if using the stock coolers.
