Case Mod - In Progress Black Dragon - MITX MOD (on hold)
Discussion in 'Project Logs' started by johnaton, 8 Mar 2012.
  1. johnaton
    johnaton What's a Dremel?
    14 Dec 2010
    The casing of choice.........
    Hardware:
    Intel i5 2500K
    Asrock z68 ITX/HT
    Exceleram 8gb x 2
    Gainward 560 TI Phantom 2GB
    Cruical M4 128gb
    Intel x25-m 80gb
    Shuttle PC63J 500W
    Watercooling:
    Black Ice Xflow 120mm
    Alphacool NexXxOS XT45 120mm
    Magicool 180mm rad
    EK - VGA Supreme HF Nickel
    EK - Supreme HF Nickel
    BP Universal Ram Module 2 Dimm - Clear
    Swiftec 355 + Alphacool Laing DDC Clear Acrylic Top
  2. johnaton
    14 Dec 2010
    now alittle update, more the the mb and my new 2500k
    coolab liquid pro, damn difficult to apply but with patient the whole chip shiney
    ek supreme so cool
  3. Darkwisdom
    Darkwisdom Level 99 Retro Nerd
    27 Aug 2011
    Nice components, but a 560ti phantom, those things take up 2 and a half slots, i hope we see a nice hole for the cooler =p
  4. johnaton
    14 Dec 2010
    no worries for the phantom, cause i will be watercooling it
  5. johnaton
    14 Dec 2010
    things are going slowly with my modding
    Gainward 560 TI PHANTOM 2GB
  6. johnaton
    14 Dec 2010
    comparing it with my spare GTX 285
  7. johnaton
    14 Dec 2010
    Now the tear down
  8. johnaton
    14 Dec 2010
    next will be getting some heatsink for my vrams
  9. jhanlon303
    7 Sep 2006
    I like it.
    john
  10. johnaton
    14 Dec 2010
    thank u very much:rock:
  11. johnaton
    14 Dec 2010
    got my 500w 80 bronze flex psu from ban leong finally, cut out the psu hole and this is what i got..
  12. johnaton
    14 Dec 2010
    Finally Rams and also WB arrived
  13. johnaton
    14 Dec 2010
    TEASER ALERT
  14. johnaton
    14 Dec 2010
    custom making the vrams heat sink:
    I wonder why ppl buy a back plate for $50?? mine cost $0 buy put in 2hr o good work into it
    and heres my $0 backplate
    ok test fit and seal all the holes, its rdy to be sprayed
    GFX custom vram heat spreader finally finish
  15. johnaton
    14 Dec 2010
    did abit of modding, saw the chipset hs so small and ugly, so decided to change it
  16. peteski
    peteski long live the pc
    8 Jun 2011
    nice work so far mate i love these small buids they inspire me so much :rock: :rock: :rock:
  17. jamsand
    jamsand Minimodder
    21 May 2011
    Loving the look of that motherboard, should be an interesting mod.....It's s small and cute!!! lol
    P.S. Want those monsoon fittings so badly! lol
  18. johnaton
    14 Dec 2010
    thank you
    yes it will be small but powerful, indeed the monsoon fittings are great
  19. johnaton
    14 Dec 2010
    started on cutting the base to put the 180mm rad
  20. johnaton
    14 Dec 2010
    did a test fit...
    yes its nicely fits!
