Scratch Build – In Progress "Pulse" by Iraklis - Updated 29th 2014
Discussion in 'Project Logs' started by Herculess, 29 Jun 2014.
  1. Herculess
    Herculess What's a Dremel?
    5 Oct 2010
    Hello everybody
    That's my 2nd try to construct a pc case from scratch, as the first one "Minimal Frame" couldn't be built further.
    But proudly i am presenting you the "Pulse", HTPC and Steam streaming box which is completed 100% :D :thumb:
    Some rendered photos of the build
  2. Herculess
    5 Oct 2010
    The construction
    The materials has been used for the construction, mainly is stainless steel 304, brass for the feet and POM acetal for some other components.
    The projects was designed on solidworks so the drawings could be extracted for laser cut.
    The main idea was the simplicity of the construction, as it shouldnt has many parts or weldments. So the outter case was designed in two bended plates, and inside a flat plate where the motherboard was placed and the cables could be enclosed between the plate and the bottom cover.
    The laser cut bottom plate made in 2mm AISI 304 brushed plate, and bended.
    The top plate
    and the middle inside plate where the motherboard and all other components will be placed.
    The feet were made in brass material using a manual lathe, the bottom part in POM acetal and pressed together so the construction would not scratch my furnitures :thumb:
    Anti seize compound used in all screws, as stainless in contact with stainless could stuck forever!
    stay tuned as another update is coming :clap:
  3. Sn00k3r
    Sn00k3r What's a Dremel?
    7 Apr 2011
    pretty neat..! will follow this :thumb:
  4. Impatience
    Impatience Minimodder
    6 Apr 2014
    I'm seriously interested as to how this is going to fit together! Because it may just be me, but I dont see where the mobo's gonna mount onto that mid-plate.. And I have no idea what that "circle with a bit out of it" is going to be used for! :lol:
    Way to build up my interest! :thumb: Haha, i'm subbed and waiting for the next update now! ;)
  5. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Nice design. Minimalistic and modern-very nice.
  6. Hukkel
    Hukkel James' minion
    20 Dec 2012
    Looking nice.
    I used to be in a band named Pulse :D
    Good luck!
  7. Herculess
    5 Oct 2010
    Update 2 - machining parts
    Thank you guys for the support! Its time for the next update with some machining of the components and parts which are going to be placed inside the case.
    Six pieces of threaded round bar had been made, and will be used as stands between the bottom plate and the middle.
    More than this, 4 rectangular pieces in POM acetal material machined in the milling and cut in angle. Those will be used later to screw the top cover of the construction to the bottom plate :jawdrop:
    With the same material i made a block for the SSD which will be placed in horizontal position.
    Combining the parts above, we have the result below :eeek:
  8. Father Fuzzy
    Father Fuzzy What's a Dremel?
    14 Apr 2014
    oh this is Fantastic :clap:
