Level 10 gt ER36PO UPDATE complated As ı said “ an update is coming soon with a new MB “ İt is ready. Lets go.. The old case THERMALTAKE level 10GT. Snow edition , with new hardware as new worklog. CASE MAINBOARD VIDEO CARD PROCESSOR (CPU) STORAGE (HDD+SSD) RAM 4X4 Gsekill Tridentx cl10 USED FOR WATERCOOLİNG FITINGS KOOLANCE 380i CPU blok RAM blok BITSPOWER WATERBLOCK GPU XSPC PUMP-TOP-RES. XSPC PHOTON 270 ACRYLIC 8/12 mm OTHER WORKLOGS PlayDoh Silverstone TJ07 - Acrylic tubing http://forums.bit-tech.net/showthread.php?t=267324 SAK SAK 900 D CASE http://forums.bit-tech.net/showthread.php?t=271227 JUMBO CASE http://forums.bit-tech.net/showthread.php?t=266554 TERMINATOR CASE http://forums.bit-tech.net/showthread.php?t=267028 12 Angry Men 900 D Case http://forums.bit-tech.net/showthread.php?t=266585 mmt 900D Case http://forums.bit-tech.net/showthread.php?t=266954 How to make BENCH CASE from an old ATX http://forums.bit-tech.net/showthread.php?t=277334 self made COSMOS II Clear Panel http://forums.bit-tech.net/showthread.php?t=277478
MOUNTİNG WATERBLOCKS MOUTİNG PUMPS AND FİTTİNGS OF PUMP MOUNTİNG FITTINGS ON MİDDPLATE MIDDPLATE MOUNTED
update 29/08/2014 FIRE UP My friend didi not wannt to use colored fluids this time , he used deionized water + antifreez
update 05709/2014 ADDING COLOR WİTH LED My friend did not wannt to use colored fluids this time , but he used color leds...
upgrade-update 17.11.2014 An upgrade with a second TITAN is ready. Hardware ThermalTake: Level 10 GT inspiration. Aero: Strike-X 1100 Watt. Asus: Rampage IV Black Editin. Gsekill: TridentX cl 10, 16 GB, 2400 MHz. İntel: İ7 4930K. Asus: GTX Titan 6 GB. Gigabıyte: GTX Titan 6 GB. Samsung: 840 pro 256 GB. İntel: 240 GB. Seagate: 2 TB. and some photos from the case Test results comming soon.
Level 10 gt ER36PO Old worklog THERMALTAKE level 10GT. Snow edition Used MB ASUS SABERTOOTH X79. CPU İ7 4930K. Ram HI-LEVEL1600 Hz. Video Card ASUS GTX TİTAN. PSU Aero Strike 1100 watt: 240 gb SSD Kingston 240 gb SSD intel 2 TB WD HDD GPU block XSPC Rad ALPHACOOL UT60 240 RAD ALPHACOOL UT 60 360 CPU block KOOLANCE 380i 2X RAM block BİTSPOWER 2x XSPC PHOTON 270 COMBO REZERVUAR FITTINGS Bitspower Matte Black Multi-Link For Acrylic Tube 12mm Case THERMALTAKE level 10GT. Snow edition Some photos http://www.dailymotion.com/video/x1ke91m_pc-sivi-sogutma-sistemi-pc-liquid-cooling-system_tech an update is coming soon with a new MB OTHER WORKLOGS SAKSAK 900 CASE http://forums.bit-tech.net/showthread.php?t=271227 PlayDoh Silverstone TJ07 - Acrylic tubing http://forums.bit-tech.net/showthread.php?t=267324 JUMBO CASE http://forums.bit-tech.net/showthread.php?t=266554 TERMINATOR CASE http://forums.bit-tech.net/showthread.php?t=267028 12 Angry Men 900 D Case http://forums.bit-tech.net/showthread.php?t=266585 mmt 900D Case http://forums.bit-tech.net/showthread.php?t=266954 How to make BENCH CASE from an old ATX Case http://forums.bit-tech.net/showthread.php?t=277334
