Hardware Nvidia GeForce GTX Titan X Review
Discussion in 'Article Discussion' started by Combatus, 17 Mar 2015.
  1. Combatus
    16 Feb 2009
  2. Nexxo
    23 Oct 2001
    Tasty, but how much?!? :jawdrop:
  3. Mister_Tad
    27 Dec 2002
    At least it's significantly quicker than second-best, price aside. Weren't the last couple rounds of Titans barely quicker than the fastest "normal" cards?
  4. bulldogjeff
    2 Mar 2010
    Tri SLI any one ? Be rude not to, just for the hell of it.
    All under water of course .
  5. IanW
    IanW Grumpy Old Git
    2 Aug 2003
  6. Hustler
    Hustler Minimodder
    8 Aug 2005
    Sigh, if AMD were offering decent competition, this would/should have been launched as a 980 Ti with 8GB of VRAM for £599.
  7. Guest-56605
    Guest-56605 Guest
    Were AMD even capable of producing anything to compete with nVidia for speed, you'd likely see a clause in the small print that requires you lease a sub station from the National Grid to power the bloody thing...
  8. The_Crapman
    5 Dec 2011
    It's fast, it's expensive, it will sell like crack-laced sherbet fountains. If I win the lottery tonight I'll be buying at least 2.
    I'm a little surprised it didn't do a bit better at 4k than it did, what with it's ridiculous 12gb of vram, but that's probably more for when VR kicks off. Probably didn't go above 6gb usage in the testing.
    No, the previous titan was about 1.5x faster than the normal cards of the time (680/7970) and that wasn't even with all the cores enabled.
  9. Mister_Tad
    27 Dec 2002
    Shows how much I follow these things. Was it that there was a "normal" card that was released shortly thereafter than was 90% of the Titan?
  10. Otis1337
    Otis1337 aka - Ripp3r
    28 Nov 2007
    give it till early summer and there will be a smiled down 6GB version
  11. Harlequin
    Harlequin Modder
    4 Jun 2004
    GTX 780....
    btw , did this throttle when it hit the design limit of 84 degree`s? being reported elsewhere about that , and it runs very very hot (hotter than the AMD cards tested)
  12. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
    780 Ti as well. Which was actually faster!
    Depends what you count as throttling. In extended tests it was running at a constant 1,139MHz, which is still signficantly above the rated boost clock (1,075MHz), whilst at its maximum temperature. That's standard behaviour for this style card, so not really. As for temperatures, it runs no hotter than the other cards that use this cooler - they all run at around 83 degrees under sustained load. The difference is in clock speed and noise. This is a lower temperature than reference 290X/290 cards.
  13. Harlequin
    Harlequin Modder
    4 Jun 2004
    reference maybe but noisier and hotter than custom cards *twin frozr for example)
    seem there will be no custom cooled cards for titan x this time
  14. Otis1337
    28 Nov 2007
  15. Harlequin
    Harlequin Modder
    4 Jun 2004
    we`ll see a 6gb GTX 980Ti ')
  16. rollo
    rollo Modder
    16 May 2008
    If i had more cash than sence id buy 2. That single card performance is exeptional stuff. Now we just need it to come down so the normal people can buy it.
  17. dolphie
    dolphie What's a Dremel?
    6 Jul 2012
    Been waiting for something to handle 4k gaming and VR and still haven't seen it yet. The 780's were miles off, big disappointment. The 980's were a bit closer. This is getting good now, but I'd never pay that much. Hoping by the time the VR headsets release later this year and early next year, there will be cards as fast as this for around £300-400 ish. SLI is useless if you happen to like a game that doesn't support it, so getting a very fast single card that can handle future upgrades (4k / vr headsets) is a big deal. I also hope the next generation which match this speed or beat it can do so without requiring water cooling.
  18. law99
    law99 Custom User Title
    24 Sep 2009
    Fair enough Nvidia.
  19. dolphie
    6 Jul 2012
    The leaked specs of the new AMD card puts it at exactly the same fps as this. It shows 60% faster than the r9 290x and when I worked that out for one of the games (at 1440p) it was the exact same fps as the Titan x. So hopefully once that shows up it will improve the prices. Hope it comes out at about 450-550 ish and not 800+ like this card. I also like the idea of the water cooled version so I don't have to do it myself.
  20. Harlequin
    Harlequin Modder
    4 Jun 2004
    with the die size reported to be 632mm2 - its right on TSMC`s fabrication limit of 650mm2.
    this is it people - the full fat Maxwell. and no DP on the quadro cards either (same core)
    so either a die shrink or new tech for the next time out
Tags: Add Tags
