News OCZ launches budget SSD
Discussion in 'Article Discussion' started by CardJoe, 11 Mar 2010.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. 13eightyfour
    13eightyfour Formerly Titanium Angel
    9 Sep 2003
    It all depends on what the UK pricing comes out at imo, if it hits the £60-£70 mark then i may pick one up just as a boot drive but ive got a feeling its going to be nearer £100 in which case ill give it a miss.
  3. rickysio
    rickysio N900 | HJE900
    6 Jun 2009
    If it comes out in Singapore for under S$100 (I'm hoping) I'd have a new boot drive.
  4. Mentai
    Mentai What's a Dremel?
    11 Nov 2007
    I could use this, my old boot drive died so right now I have everything on my 2tb raid config which was originally intended for storage. I don't fancy having to reformat that if something goes wrong haha
  5. Naberius
    Naberius What's a Dremel?
    20 Nov 2006
    Would be pretty good as a boot drive for my media centre, all depends on the price though. If it comes in at £65 or less then I might have to pick one up.
  6. mi1ez
    mi1ez Modder
    11 Jun 2009
    Yay.
    Another cheap SSD offering the same or lower performance than a high end HDD at a lower capacity and higher price.
  7. rimscar
    rimscar What's a Dremel?
    21 Aug 2009
    did have a 60gb SSD, but it failed after a month, so returned. That model deconned, had the option of replacement or refund.
    As i`m getting new tech overload and my poor old brain is struggling to keep up with all the shennanigans of firm trimware or trim firmware or ware trimfir or whatever else plagues the SSD market, i opted for the refund.
    I`ve only just come to terms with BD, HD, hdmi etc!!
    I realise that this is all the fun of the fair for early adopters, but there comes a point where i can't be ar*sed with all the faffing around, so have decided to hand over the bucks when the tech settles down a bit more and stabilises......./flamebait lol
    And 30gb?? Way too small, as the wife so often complains...
  8. rickysio
    6 Jun 2009
    It's all about access times.
  9. Redbeaver
    Redbeaver The Other Red Meat
    15 Feb 2006
    this is a good start.
  10. tonyd223
    tonyd223 king of nothing
    12 Nov 2009
    talk to me in a year...
  11. crazyg1zm0
    crazyg1zm0 Minimodder
    20 Feb 2007
    I am happy to hear the prices are coming down as I am wanting one as a boot but can't afford the prices yet
  12. trig
    trig god's little mistake
    10 Aug 2006
    is trim supported?
  13. tank_rider
    tank_rider What's a Dremel?
    3 Feb 2005
    Looking forward to a review of this. Would be a nice new boot drive to compliment win 7 that I've just loaded on. It's the right time too as I've not got many apps etc installed onto the fresh win install so it isn't too much of an effort to change drive :) I guess like has been said, it depends on how the pricing translates across the Atlantic.
  14. Jehla
    Jehla Minimodder
    8 Jan 2010
    So will this drive deliver ~40sec win7 boot times?
  15. CampGareth
    CampGareth What's a Dremel?
    15 May 2009
    This is a step in the right direction, but what I'd like is to be able to purchase a pre-made board with a controller and maybe a RAM chip on it, then I could buy my own flash chips from the various reseller sites and solder them on as a real enthusiast would back in the days when manufacturers didn't cater for modding.
  16. rollo
    rollo Modder
    16 May 2008
    a ordinary hard disk boots win 7 in less than 40 seconds
  17. Anfield
    Anfield Multimodder
    15 Jan 2010
    Depends on where you measure from, if you include the time the mainboards wastes before even starting to load the data from whatever kind of storage you use you will have a hard time getting below 40 secs (especially on high end boards with all the latest and greatest stuff and dont even look at raid if you care about boot times measured from the the time you push the power button).
    But if you just look at the time it takes to boot from when the system actually starts loading windows no sdd (not even first gen jmicron cr*p) will ever take anything close to 40 secs.
  18. cybergenics
    cybergenics What's a Dremel?
    27 Jun 2009
    Measuring a disk or PC's boot time is a spurious past-time. Youtube is full of videos of people claiming their PC or Mac is fast because it boots Windows or OSX in a short time. Any fresh installation devoid of applications will boot WIndows quickly, even without tweaks and on slow disks. When you start having Itunes and sludge that Adobe installs running at startup, that's when you boot times travel back into the dark ages. I had Pentium M laptop running XP that booted in about 20 seconds, from hitting the power key to being ready to use. But had a Q6600 system at 3.5 running XP (before Vista was installed) with faster drives, more ram etc, that took about a minute.
    In other words, its naff all to do with hardware, boot times, most of the time.
  19. Jipa
    5 Feb 2004
    Looking forward to some benchmarks.. One use would be to replace my laptop drive. In that use I just don't need capacity, all I want is fast boot and long battery life..
  20. Jehla
    Jehla Minimodder
    8 Jan 2010
    I'll rephrase that then. Will this drive deliver a considerably faster boot up time compared to a high end hdd?
Tags: Add Tags
