Watercooling A question about passive cooling
Discussion in 'Hardware' started by Fabou, 2 Dec 2010.
  1. Fabou
    Fabou What's a Dremel?
    22 Apr 2010
    I just wanted to know if anyone have tried WCing with an house rad.
    My question are is there a lot of material compatibility problem (same as alu/cooper in one loop)
    Is it worth the price new (that would surprise me as nobody use them)
    Is it worth is you found one for free as a passive system (for a not moving PC obviously)
  2. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    What are you wanting to cool?
  3. Fabou
    22 Apr 2010
    Well it would be my processeur a core duo but it is not sure at all.
  4. Bloody_Pete
    11 Aug 2008
    What style of radiator...?
  5. M7ck
    M7ck Ⓜod Ⓜaster
    28 Mar 2009
    Household radiators are not passive. If you wished to use one as a passive cooler I think you encounter a lot of problems, as in how would you transfer the heat from cpu to the radiator?
  6. Teelzebub
    27 Nov 2009
    You would need some powerfull pump for that lol
    I've seen someone use a car heater rad and a small electric car radiator fan.
    Worked pretty good too.
  7. Fabou
    22 Apr 2010
    Well I mean raccording this to your WCing loop. [​IMG]
  8. M7ck
    M7ck Ⓜod Ⓜaster
    28 Mar 2009
    In theory you could hook it up but how do you suggest cooling the fluid?
  9. padrejones2001
    padrejones2001 Puppy Love
    17 Jun 2004
    Box fan? It sure would move a lot of CFM.
  10. Fabou
    22 Apr 2010
    Well my question is would the rad be able to cool the fluid. It's what they do normally right, exchanging heat from the water of the house boiler with the air of the piece. So technically they should be able to exchange heat from the CPU with the air.
  11. Rofl_Waffle
    Rofl_Waffle What's a Dremel?
    24 Mar 2010
    There are three vairables when considering heat exchange. Temperature difference, thermal conductivity, and contact.
    Contact with the air plays a significant role. The raidator can either be bigger or have fans to push the air onto the surface. Even though household radiators are so big, the volume of air surrounding it, is small compared to what multiple 120mm fans can push into a typical computer raidator.
    A typical 3x120mm radiator with fans usually have a temperature difference of 10C between the water and the air. While household radiators take much hotter water to heat the house only a little.
    The only way you can get better performance is increasing the temperature difference. If you mounted it outside instead of inside the room for instance.
