The thread is flickering
Discussion in 'Feedback & Suggestions' started by tranc3, 1 Dec 2008.
  1. tranc3
    tranc3 ADHD Modder
    16 Jul 2007
    This has happened a few times on a few different threads, while the page is loading my fire fox window will flicker not the fire fox program, not my screen but the thread inside the program will flicker rapidly not sure if my connection (dial up) is causing it but ether way thought it should be know its not a big problem i just keep thinking im having a hard ware failure. and this hasn't happened during any other program, web page or any thing.
  2. crazybob
    crazybob Voice of Reason
    21 Oct 2004
    Sounds like malware to me. I'd run a scan with your antivirus program (AVG Free is an excellent choice if yours is outdated or you don't have one), and a scan with Ad-Aware or Spybot-S&D.
  3. tranc3
    tranc3 ADHD Modder
    16 Jul 2007
    Doesn't seem to be malware, I experienced the same on the computers in school, and also at my girlfriends. I was also using IE in school, i think its when the images are resizing it flickers.
  4. jhanlon303
    7 Sep 2006
    I'm running Vista 32 bit with FireFox and I've seen it a lot too. I usually only go to modding, project logs, and general and it happens occasionally on all 3. Usually happens on threads with a lot of pictures like "post your desktop"
    john
  5. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    does it flicker indefinitely or just while it's loading? if the page loads partway scrolled down it might look like it's flickering as the images load and move the page down to accommodate them.
  6. jhanlon303
    7 Sep 2006
    That's what I see. I vertical, up and down sliding around. Especially noticeable if you click on "view first unread" .
    Stabilizes after resizing pics. Bothersome but bearable.
    john
  7. tranc3
    tranc3 ADHD Modder
    16 Jul 2007
    Yea that's whats doing it, i cleared my cache then reloaded a page that did and it starts doing again I'd under stand the page "snapping" to forum to the images but the page is flicker from dark blue (back ground) to white of the foreground/table.
  8. keir
    keir S p i t F i r e
    5 Oct 2003
    Try turning off the highlight thread with new posts, in the user CP.
  9. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    Try changing the image resize settings in your user cp.
  10. tranc3
    tranc3 ADHD Modder
    16 Jul 2007
    Yep that dose the trick. oddest thing tho. I'll still keep resizing on it makes it much neater when reading project logs. (turning off the resizing)
  11. jhanlon303
    7 Sep 2006
    I think it might be a function of screen size. I get the flicker on my 19" monitor but not on the 32"
    Weird. But as I've said it's livable.
    john
