Education Sky in second room
Discussion in 'General' started by noizdaemon666, 27 Feb 2015.
  1. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    Hi guys,
    My neighbour has a Sky+ HD box in her living room. She also wants to be able to watch upstairs. What's the easiest and cheapest way of doing this? 2nd Sky box? Or something else?
    Cheers
  2. GMC
    GMC Minimodder
    26 Jun 2010
    Sky Go and a PC/laptop/chromecast similar might be an option?
    Actually, Chromecast and a compatible android phone would offer all the main internet on-demand channels that have apps.
  3. David
    7 Apr 2009
    Other than Sky Multi-room or whatever they call it now, can't you get some cheap efforts off ebay that let you control the sky box in the lounge from another room and receive the same signal in there too?
    Unless she wants to be able to view one channel in the lounge and a different one in the bedroom - in that case I think she's back to the Sky multi-room thing.
  4. Snips
    Snips I can do dat, giz a job
    14 Sep 2010
    If you want to be able to change the channel and not necessarily want HD, you can just use coax cable and one of those eye thingy's. I was looking at all options but nothing else allows you to change the channel other than that or a second sky box of course. I believe multi-room is about another £10 a month and an extra £5 for HD but then both rooms can then watch something different.
  5. Pookie
    Pookie Illegitimi non carborundum
    4 May 2010
    I have a LNB with 4 cables coming out into the house. 1 pair goes into the living room and the other pair goes into our daughters bedroom. If my daughter wants to watch sky in her room we just give her the card and she takes it upstairs.
    For our bedroom we just use the sky Go app to watch TV. I think asking an £10 for an additional card is a rip off! As long as you have a decent unlimited internet connection I suggest using the Sky Go app.
  6. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    If the need is to be able to watch different programs in different rooms then she will be after Sky multi-room.
    Set up cost (engineer visit): £60
    Monthly subscription: £11.25
    Second box cost: Free (only for non recordable box), however £199 if you want a Sky+ HD
    Or use the Sky Go app - Free but limited to size of the device you play it on.
  7. tyepye
    tyepye Minimodder
    20 Dec 2010
    I have this:
    http://www.amazon.co.uk/One-For-All...e=UTF8&qid=1425027010&sr=1-1&keywords=sv+1730
    Which works well for me. Controls the box downstairs and sends the signal upstairs. Quality is SD as it connects using the composite socket but it's fine for the bedroom TV. Use the Sky+ app on your phone to control the box and you can leave your normal remote downstairs.
    Obviously though you can't watch different things upstairs and downstairs. If she wants that then multiroom would be the way to go.
  8. GMC
    GMC Minimodder
    26 Jun 2010
    Unless said device is an android phone and you cast the screen to a Chromecast plugged into whatever TV/screen you like
  9. noizdaemon666
    15 Jun 2010
    Thanks guys. She's going with something similar to tyepye's kit. She's fine having same on both TVs.
  10. Zoon
    Zoon Hunting Wabbits since the 80s
    12 Mar 2001
    I am using coax to link from lounge to my bed, and I'm using the Sky+ app as a remote control. You just need to get your box on the net either with wifi dongle or cable it to your router.
  11. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    Don't you have to hack it to work though?
  12. Plugs
    Plugs Minimodder
    5 Nov 2009
    We have our Sky signal sent around the house via coax cables from the output of the Sky box. The output will be on an analogue channel. Newer boxes don't have a coax output (a.k.a. RF2?) you can use in this way, but they do come with an IO port that you can get a converter for.
    You can even get "magic eye" infra red receivers in the other room that feed back to the sky box (allowing you to change the channel with a sky remote without having to go the skybox) . However if you send it to more than one room, you will probably need an amplifier (mains powered), otherwise the signal strength goes too low.
    Setup would be:
    Dish -> SkyBox ->RF out -> IO converter -> Magic Eye -> Second TV
    or
    Dish -> SkyBox ->RF out -> IO converter -> Amplfier -> Multiple outputs to multiple magic eyes/TV
    (Both setups can still connect the skybox to the main TV via an HDMIcable)
    example IO converter: http://www.amazon.co.uk/Global-Link...F8&qid=1425420812&sr=1-4&keywords=sky+tv+link
    example magic eye: http://www.amazon.co.uk/Global-Magi...UTF8&qid=1425421096&sr=1-1&keywords=magic+eye
    example amplifier: http://www.amazon.co.uk/Professiona...qid=1425421129&sr=1-12&keywords=sky+amplifier
    *I just searched those on amazon, I don't own (and therefore cannot recommend) these exact items
