Hardware Fractal Design Define XL Review
Discussion in 'Article Discussion' started by Claave, 19 Nov 2010.
  1. Claave
    Claave You Rebel scum
    29 Nov 2008
  2. memeroot
    memeroot aged and experianced
    31 Oct 2009
    looks nice though
  3. mi1ez
    mi1ez Modder
    11 Jun 2009
    I wonder what sort of a difference another 140mm fan would make in the uppermost mount.
    Pity Fractal didn't include this fan given the poor stock CPU performance.
  4. Ljs
    Ljs Modder
    4 Sep 2009
    "so instead of a single 120mm intake fan there’s room for two 140mm intake fans"
    Doesn't the R3 have room for two 120mm fans at the front?
  5. SlowMotionSuicide
    SlowMotionSuicide Come Hell or High Water
    16 May 2009
    About a bloody time someone actually saw the case. Shame about performance, and also shame this case isn't still available even though Finnish retailers have had it listed for about 2 months now. I got tired of waiting, so I got myself a nice fat 800D instead.
    Hope they bring out something in mATX next.
  6. bulldogjeff
    2 Mar 2010
    so its bigger and not better. Shame cos it has the potential to be so good
  7. Paradigm Shifter
    10 May 2006
    I can't help but think this could do with growing about an extra inch taller, and using that increase to put a bit more space between the bottom of the mobo and that internal division...
  8. Lazy_Amp
    Lazy_Amp Entry AMD Engineer
    17 Jul 2010
    Yeah, since both CPU case fans are exhaust, probably not very great there.
    All these with big top exhausts would probably do pretty well with a H50 pulling hot air in.
    I think the angle on the top... probably doesn't help at all...
  9. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    I have to admit I like Fractals cases.
  10. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    If it wasn't for that stupid side panel fan I'd buy about 12
    I really ruins the look
  11. Skill3d
    Skill3d Minimodder
    29 Sep 2005
    Guys fix your "s" key... There seem to be missing lots of s's in the article...
  12. Phoenixlight
    Phoenixlight What's a Dremel?
    29 Oct 2010
    What side panel fan? From the pictures it doesn't look like there is one. I like the look of the case overall and GPU cooling is more important that CPU cooling because you can always buy a cheap aftermarket cooler for a CPU, you can't do that for a GPU though so it's not bad.
  13. Guest-23315
    Guest-23315 Guest
    Looks like a natural evolution from the P180/P182... without the stupid extra sticky outy bits.
  14. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    I think Beast means the fan cutout shown in this pic:-
  15. okenobi
    okenobi What's a Dremel?
    3 Nov 2009
    Is it me, or do E-ATX cases just suck for cooling (pun intended)? The ATCS840 review similarly blames the cavernous interior for ruining airflow from the intakes to the hot stuff. Makes you wonder if they're useful for anything other than servers....
  16. stonedsurd
    11 Mar 2009
    This. I love the way it looks, I want to watercool one but the side panel is very off-putting. Shame.
  17. azrael-
    azrael- I'm special...
    18 May 2008
    At least this time they seem to have managed to have identical case feet all the way round...
  18. xaser04
    xaser04 Ba Ba Ba BANANA!
    27 Jun 2008
    Yep, 2x 120mm just like the R2.
    Would a HD5970 (and presumably the equally large HD6990) actually fit in this case? It looks to be a bit of a squeeze with a HD5870 (Just like the R2/R3).
  19. Material
    Material Soco Amaretto Lime
    13 Apr 2010
    Yes you're correct on this, that's my bad, I've fixed it in the review.
  20. Material
    13 Apr 2010
    Believe it or not we actually answer this in the review ;)
Tags: Add Tags
