News AMD Ontario performance numbers leaked
Discussion in 'Article Discussion' started by CardJoe, 30 Jul 2010.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. MrJay
    MrJay You are always where you want to be
    20 Sep 2008
    Me likey!
    been itching to get on with a new ITX build, looks like a board based around this chip would be a winner.
  3. Phalanx
    Phalanx Needs more dragons and stuff.
    28 Apr 2010
    That's stunning. I'll hold off building my HTPC until this launches then :)
  4. mjb501
    mjb501 What's a Dremel?
    20 Jun 2010
    Looks very promising.
  5. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    Looks promising, though I think I'd be more receptive of it if it could match the performance of the 250u listed; still if it can do all this in the power/thermal envelope of the Atom, that'd be impressive.
  6. Evildead666
    Evildead666 What's a Dremel?
    27 May 2004
    Very impressive indeed.
    Why they tested on Server 2008 R2 for an atom oriented type of chip could indicate that Low-power servers may also be powered by such chips...
    How many could fit in a 1U blade ?
  7. general22
    general22 What's a Dremel?
    26 Dec 2008
    Pretty shifty benchmark, 3 different operating systems (Yes I know they are the same core). Still it looks like they made a good low power CPU for a HTPC with the integrated GPU.
  8. crazyceo
    crazyceo What's a Dremel?
    24 Apr 2009
  9. javaman
    javaman May irritate Eyes
    10 May 2009
    Will a version of this be hitting the gap between netbooks and cheap laptops sort of where the CULV processors sit or is neo challenging that spot?
  10. rickysio
    rickysio N900 | HJE900
    6 Jun 2009
    And the next thing we know, Intel issues press release : Next Gen Atom, with similar TDP but tripled performance bound... one month before Ontario launches.
  11. CowBlazed
    CowBlazed What's a Dremel?
    9 Dec 2005
    11-12" netbook with this is a complete win.
  12. borandi
    borandi What's a Dremel?
    27 Jan 2010
    You mean 1.352 GFlops, not 1,352. 1,352 GFlops puts it on par with the GTX480.
    (On the continent, they use a comma where we use a decimal point. The french call it 'le point' I believe.)
  13. ChuckyP83
    ChuckyP83 What's a Dremel?
    20 Sep 2008
    You could say 1,352 Megaflops...
    Just sayin...
  14. alwayssts
    alwayssts What's a Dremel?
    20 Feb 2009
    Yes. Is it effectively replacing Neo in that area.
    Llano will be replacing the regular laptop lineup.
    AFAIK AMD (per their roadmaps) does not plan to offer a triple or dual core Llano for laptops, only quad-core, which leads me to assume Ontario will fill that segment.
  15. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    wow that could be an Atom killer right there given the wider range of support and most likely HD support as well. hmm I have a 12" ION Netbook but I would be happy to replace it with a similar model of this. ^_^ and I bet will have much better battery life too.
  16. Blanx3_Bytex
    Blanx3_Bytex What's a Dremel?
    3 Feb 2010
    crazyceo are you seriously uninterested in a new product that could give the mobile market a proper shakeup? or maybe suspect fanboy-ism is at work...
  17. ssj12
    ssj12 Minimodder
    12 Sep 2007
    looks like Intel needs to step their game up on the low powered CPUs now. Interesting turn of events.
  18. null_x86
    null_x86 Thread Closer
    18 Jan 2009
    numbers look pretty damn impressive, but why make it a x86 architecture? Why not x64?
  19. HourBeforeDawn
    26 Oct 2006
    Everybody listen CrazyCeo was simply born with a negative outlook on life, if you notice ALL his post tend to be negative so dont waste your time with him and just move on for more worth wild post.
  20. Bakes
    Bakes What's a Dremel?
    4 Jun 2010
    No, I've seen some positive posts ;)
    I'd only say that he has an unusually negative outlook on AMD and ATI products in general.
Tags: Add Tags
