Graphics Crossfire 5770 with 5750?
Discussion in 'Hardware' started by tim230, 24 Mar 2011.
  1. tim230
    tim230 What's a Dremel?
    24 Mar 2011
    This might be a nooby question but I need an answer. Can I crossfire an hd 5770 with an hd 5750 both xfx? :worried:
  2. murraynt
    murraynt Modder
    6 Jun 2009
    You can indeed but the 5770 will downclock it's self to the 5750 levels.
    EDIT: Welcome to Bit-Tech
  3. penryn 2 hertz
    penryn 2 hertz I'm not a science fiction writer...
    10 Jun 2010
    i wasd thinking the same i have a 5770 myself is it werth buying a nother 5770 to crossfire i know when you add 2 5770's its equle in specs as the 5870 is
  4. trig
    trig god's little mistake
    10 Aug 2006
    I would check for reviews of 5770 x-fire and the how it handles the games you play...should be pretty decent though...
  5. KidMod-Southpaw
    28 Sep 2010
    I'd say you'd get decent results. The 5770 will downclock to 5750 level buy it'll still do well with ok temps. What case do you have?
  6. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
  7. tim230
    24 Mar 2011
    I have a lanboy air case:)
