Case Mod - In Progress CORSAIR CRYSTAL 570X Mod -WTLO-
Discussion in 'Project Logs' started by kier, 27 Nov 2016.
  1. kier
    kier -----------------
    1 Mar 2011
    It's a real privilege to work on a Corsair case again, but this time it's a very special case. I'm trying to make something beautiful with a case that already is awesome.
    Fitted with tempered glass and combined with RGB fans this chassis already got a delicious look, feel and design.
    So this will be a big challenge! What also keeps me awake is the knowledge that some of world's best casemodders also received the case to do there special things with it.
    Anxious to know what you guys will do to this beauty gives a bit of high blood pressure but also great vibes to make something good.
    I will name my build "WTLO"
    Corsair likes to do it With The Lights On these days, and in this build Lights (RGB) will be a very important subject.
    First of all, I would like to thank Blake, Harry and all of the Corsair guys who keeps believing in my builds and supported me for quite a long time now.
    Let the party begin....
    Specs:
    Case: Corsair Crystal 570X RGB
    CPU: Surprise
    Motherboard: MSI X99A GAMING PRO CARBON
    GPU: GTX1070
    PSU: Secret
    RAM: Dominator platinum
    Fans: 6x HD120 RGB LED PWM Fan
    Cooling: Custom water cooling
    And much, much more, but will reveal this later.​
    Episode 1
    Must admit, didn't take pictures when the case arrived.
    Waited a long time for this beauty so pretty enthusiastic to start.
    The Corsair Crystal 570X RGB
    I've got some ideas to make it possible to transform the case in every color you want.
    This for the inside and outside:
    Adjusting colors inside will be with RGB LEDs using the Corsair HD120 RGB fans and RGB strips/ controllers
    Outside I will add use vinyl wrap on both sides of the tempered glass.
    One side black and the other side white.
    I also moved the Corsair logo from the left side into the middle to make it possible to flip the side panel and still see the logo.
    And added RGB LED behind the logo.
    To have the logo in the middle I made a midplate cover and a piece of acrylic. This will be modified later on.
    So added black vinyl and did some cutting to get borders.
    In this stage I'm still not sure if I will keep the borders because I want it a more "glass" appearance. I like it like this very much, but I don't want it to look like a "normal" case.
    Designed 3 holes on a piece of black vinyl to show the beautiful Corsair SP120 RGB fans that came with the case... and pasted it on the front panel
    After this I also made the pieces in white... The real challenge was to get it perfectly aligned with the black on the other side.
    Last task in this episode is the extra fan on top. Original there is space for Two 2 x 120/140mm fans on top, but I want 3x 120mm fans on top just like the front.
    Also I want everything aligned... top and front. So for this I did my first cutting in the case.
    Made a bracket to hold 3 fans and after some adjustments installed it.
    The original top plate has a recess on the right side to operate the buttons. When flipping the panel to get another color this would look silly and it would not be possible to reach the buttons.
    So made a new top plate from smoked acrylic with recesses on both sides.
    Hope you like where this is going?
  2. kier
    1 Mar 2011
    Episode 2
    Hi Y'all,
    Decided to cut the vinyl borders from the side panels, meaning the sides and top to give it a more glass look. Like I said before with the borders it looks like a "normal case".
    So only did the side panels... the front and top are imho pretty good like this.
    Then a beautiful "early Christmas" present arrived:
    Nice goodies that I will show in progress of the build. But there is something in the box that I was really waiting for... The HD120 RGB fans.
    These are also amazing just like the SP120, but they are much brighter and perfect for this build.
    Small vid regarding fans installed and in show mode:
    More to come!
  3. kier
    1 Mar 2011
    Episode 3
    Good evening my modding friends,
    Time to go inside the Corsair 570X :hip:
    Because this build is all about changing colors I wanted to get the color change also inside. For this I have used a few RGB strips and another Corsair controller that came with the HD fans.
    So I used 1 strip below my custom made midplate, one on top of the midplate and one within the small space of the radiator bracket.
    Next I've made a Corsair plate with on the front and back white vinyl. After this I pasted the matt black with Corsair logo on top of the white. The white on both sides is for better light distribution.
    the RGB strip on the midplate is for the custom reservoir. The idea is to use clear transparent liquid, so when you want to choose another color of the internal lightning, the liquid also change in this color.
    And made another plate to cover the side of the reservoir.
    Of course some color change pics :dremel:
    And a small video of the Corsair Crystal 570X in RGB show mode :cooldude:
    Hopefully next update will be with some awesome hardware I have chosen for this build.
    To be continued!!!
  4. WaRn00b™
    WaRn00b™ bit-tech addict
    14 Jan 2013
    Damn... this design looks better than it looks from the factory!! Well done man.
  5. C4B12
    C4B12 Minimalistic PC's
    6 Oct 2011
    Awesome job Kier!
  6. kier
    1 Mar 2011
    Episode 4
    Hi y'all,
    After these couple of days with lots of beer and pretty much overfed every day, I still have done some progress regarding the Corsair 570X RGB build.
    A bit late regarding Christmas but... wishing you guys a happy holidays and a great new year. Hope you all will find peace and happiness.
    The Corsair 570X RGB continues:
    I love what Corsair did to take care of the cable management. For this they designed a nice cover to put everything behind.
    But I'm gonna try to take it a step further.
    before this, I also did some cutting in the case to make it easier to acces the pump beneath the midplate/ reservoir.
    I've made a piece of acrylic to measure the space behind the mobo tray and plotted some vinyl with the Corsair logo. Also cut out a piece to get a nice little window for the
    Corsair Force Series™ LE 240GB SATA 3 6Gb/s SSD
    And with some minor adjustments and adding a RGB stip connected to the 6 port RGB LED hub it looks awesome:
    I also started to work on the custom reservoir with tapping holes for the adapters. Don't have the final hardware but most of the measurements are possible to make and place the hardware later.
    In the middle to the right side beneath the reservoir is the inlet for the pump.
    In the back on the right there is the outlet pump, connected to the radiator.
    And outlet radiator connected to the reservoir is on the right on top in the middle of the res. This will be a "fake" adapter to hold this line in place... more on this later.
    And also added a fill port on the left of the reservoir
    After installing the (provisional) hardware this will be the loop...
    One line to function as an inlet for both parts... the inlet CPU and the Inlet GPU. This with valves to controle the flow of the liquid.
    All outlets are going straight into the reservoir
    Last part for this update... playing with the RGB as always :)
    Maybe there will be another update before this year ends! If not... Happy new year and hoping to see you all next year!!!
  7. kier
    1 Mar 2011
    Episode 5
    hi guys,
    Best wishes and blessings for this new year!
    What better way to begin this new year with finishing a build and with this another update :)
    Finally my new motherboard is in which will fit perfect in this RGB build.
    The MSI X99A Gaming Pro Carbon:
    Once installed its time to connect everything and worrying about the details
    Added some more vinyl to the reservoir. without I thought it was a bit to bright when the lights are on
    Also did some Dominator modding to match the "theme"
    Going fast, but after all off this I really wanted to startup everything... So, First startup!!!
    Really love this RGB motherboard with all its features
    So first test: RGB going wild!!!
    Time for more smooth RGB lightning with the MSI App and the Corsair RGB controllers
    And my favorite... Green and blue
    So up and running, now some more minor details before the final shoot.
    But got a little preview regarding the shoot.
    Hope you like it!!!
    Final photo shoot next :)
  8. kier
    1 Mar 2011
    Episode 6: Final
    The build is finished and on his way to the US.
    But not before I did the final photo shoot!
    Shot a lot of pics because of the endless possibility's: switching panels, different color zones, RGB presets, etc.
    So I've made a "small" selection of the pictures to show you the diversity...
    Really hope you like it!
    Power off, " black" panels:
    "White panels"
    Bringing some more color in it:
    And not to forget the back:
    This is it!... For now :) shot a vid also and will post when finished editing.
    Thank you so much Corsair Blake, Harry and George for this opportunity and for organizing everything so fast and smooth to achieve this colorful Corsair Crystal 570X transformation.
    :clap::thumb::thumb::clap:
