Graphics 4K TV gaming now?
Discussion in 'Hardware' started by forum_user, 12 Aug 2014.
  1. forum_user
    forum_user forum_title
    4 Jan 2012
    My question to you is, do I pop out to Currys Dictafone Warehouse and buy a shiny 4K TV to sit on my desk, or are they no good for PC gaming?
    Examples of my most recent games played include: Counterstrike Source, Elder Scrolls online, Papers Please, Bioshock games, Battlefield games.
    Will I regret trying to game on a 4K TV? It's going to be £1k+ for a 40" to 50" TV and I'm unclear if we are supposed to be waiting for monitors, or faster TVs ...
    (added) I have a Titan GFX card and could double up on it, or upgrade if needed. I just want to know if now is the right time.
  2. Atomic
    Atomic Gerwaff
    6 May 2002
    TV ≠ Monitor.
    TVs are for sitting many feet away from, Monitors are for close range work.
    You will get nothing except eye strain using a TV at a desk.
  3. sandys
    sandys Multimodder
    26 Mar 2006
    take a PC in an test, make you r own mind up, I think it would be fine if input lag is OK and you can disable much of th eTV processing in a PC/game mode.
  4. adam_bagpuss
    24 Apr 2009
    or buy a 4K monitor thats much much cheaper ?
  5. Anfield
    Anfield Multimodder
    15 Jan 2010
    For 4K to work properly on a TV you can not use HMI 1.4 or older, you need HMDI 2.0.
    While some 4K TVs like for example Samsungs curved 3d smart 4k TV for over £2500 do support HDMI 2.0, many Graphicscards only offer HDMI 1.4 (or older).
    If you get a Monitor instead you can avoid the limitations by using Displayport.
  6. Jim
    Jim Ineptimodder
    2 Sep 2007
    Bad timing.
    HDMI 2 isn't an option yet, so unless your TV comes with the right Displayport connectivity, you're stuffed.
    Given that there's no real 4K TV content out there right now, I'd be inclined to go with a 4K monitor instead.
  7. Bhuvsta
    Bhuvsta Minimodder
    1 Dec 2007
    Bad idea in my opinion. I doubt that 4k tv's have Display Port or your graphics card has HDMI 2.0. This means you will be stuck at 30fps, although 30fps maybe a challenge for your graphics set up @ UHD. I'm no expert, but I imagine the response time of a 4K tv to be pretty high too.
  8. Anfield
    Anfield Multimodder
    15 Jan 2010
    Some of the current top end TVs have HDMI 2.0 already, but on the gpu end you are stuffed as not even Titan Z has it.
    However, I did some further digging and apparently nvidia has found some trickery to get around the 30hz limit for 4k on hdmi 1.4: http://www.anandtech.com/show/8191/nvidia-kepler-cards-get-hdmi-4k60hz-support-kind-of
  9. Jim
    Jim Ineptimodder
    2 Sep 2007
    I did see that article, but it sounds like a real hack-job. Not something I'd want to invest money in to achieve, although if I had the kit already obviously I'd give it a crack.
  10. paisa666
    paisa666 I WILL END YOU!!!
    4 Mar 2009
    It's something that you have to test between many brands, I own a 32" Samsung TV for gaming on my desk, the image its really great and you can find lil details on tv's that can actually help you (like many tv's try to add some kind of "anti-alliasing processing, its not the finest ofc, but it does help).
    I think the gap its closing between both TV and monitors anyway since both technologies are using the same advances.
  11. timmehtimmeh
    timmehtimmeh Minimodder
    2 Jan 2005
    I read an article on this a while back of a guy posting about his thoughts on this topic. (Hey 42" 4k or 50" 4k must be a no brainer right?)
    I believe his conclusion in the article was that the input lag was disgusting for him and there was much in the way of eye strain.
