Case Mod - In Progress Bitfenix Pandora weekend modding (plus some more days...)
Discussion in 'Project Logs' started by HCP, 15 Dec 2014.
  1. HCP
    HCP Minimodder
    19 May 2012
    Well, someone got to do it with the Pandora, so why not me ? :)
    First part of this mod is a weekend mod, i need to free up my current workstation case for a project, so im putting it into the Pandora.
    But, is it possible to just use a case without some modding? nooo :)
    Later on, a part 2 of this project will be made with some more crazy stuff.
    But, here we go for part 1 :)
    The Pandora on the table, its the Black version with window.
    After a couple of minutes, its naked!
    Time for the work to begin
    Radiator in the picture is only used for mockup, not used in a loop ;)
    When i was cutting and looking at this, it probably will be more than a weekend mod :p
    Found more and more stuff i want to do!
    Starting off with some templates to see how it may look.
    And short after, the acrylic floor.
    Time to think about holes and exits i need for cables, reservoar and front facing radiator.
    Im not really pleased with the sharp edge on the floor, probably add some rounded edge to match the rounded front panel.
  2. Iraklis Gkolios
    Iraklis Gkolios Minimodder
    21 Aug 2013
    Subbed
    My next case mod is going to be this one, ill watch you closely.
    Cheers
    Iraklis
  3. HCP
    HCP Minimodder
    19 May 2012
    Next step was to remove the top buttons, i dont like them, too big for something i hardly will use.
    I moved the power/reset to the back of the case with small push-buttons.
    Made the top panel into a smooth panel instead, added a picture of the original panel also for comparison :)
    Aaaand, what i wanted. Except for color...
  4. HCP
    HCP Minimodder
    19 May 2012
    I was stupid thinking i could be pleased with just one weekend of modding :p
    This has escalated to something more, as usual...
    I wanted to make some sort of floor to cover up the cables a bit, and somwhere to hide the pump and part of the reservoar.
    BUT, using the the cutout in the window to display the SSD, why not put the reservoar and pumpc-bombo there, so, i got to work :)
    I have a bunch of ITX motherboards, so i will go with that for this one. Maybe update later.
    Made some smooth backing to cover the holes and whatnot inside the case.
    Also has begun on the floor, due to width of the Pandora i had to cut out the PSU from the side.
    Some have asked why sinking the pump and res? - because the watercooled GPU will hit, or get a awkward position if i do not sink it into the floor, or put it horizontal and my DDC pump doesnt like that (the manual say). And already have alot of pump-res combos, not keen on ordering new stuff so i go with what i have :)
    Some pics...
    A overview
    The floor hiding everything below
    A quick rendering of the floor, just to get a feeling of what i´m aiming for.
    Pump/res is not designed accurate, just the measurements ;)
  5. jodah175
    jodah175 Wannabe Modder
    26 Oct 2006
    I love tiny case builds as much as huge case builds, but I like the results so far! sub'd. :)
  6. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    IN! This man does nice work!
  7. gavbon
    gavbon Extreme Overclocker/PC Anarchist
    6 Feb 2013
    Looking forward to seeing the final design!
    Keep us updated!
  8. HCP
    HCP Minimodder
    19 May 2012
    Waiting for some acrylic tube fittings from Bitspower, hopefully arrive tomorrow or Wednesday :)
    I´ll update it a bit more later tonight, have done the lower floor ready and fine-tuning the edges and stuff :)
  9. Cheapskate
    13 May 2007
    It needs about 700 LEDs. ;)
  10. HCP
    HCP Minimodder
    19 May 2012
    Something like this....
    Time to hit the sander and prep the panels for paint, or wrap. Haven´t decided yet wich way to go.
    I dont like the waterblock for the 7950, but its the only i have that fits in this case, Pandora is only 16cm total width.
    I´ll have to look for a nice backplate, or make my own.
    More problems.
    Was planning on using the PrimoChill Ghost fitting, but that one on the GPU is too wide.
    The side panel is 100% tight against the GPU block, and that fitting is 2-3mm more.
    Ghost fitting that´s too big down right.
    The two top ones is what i have to choose from.
    Maybe incorporate a metallic red theme... hmm
    Or... use Ghost fittings all over, except for GPU where i use the black ones? (top left)
    Here´s how it stands out.
    This is how it looks trough the panel, pump got pretty nice positioned :)
    I tested the Ghost fitting with side panel on, it doesnt bulge, and its not visible that the fitting is head on with the side panel window.
    That would be the best solution, i like the Ghost fittings.
    Third day now, still stuck on how to route the acrylic tubing :p
    Any suggestions ? :)
    First routing idea.
    Pretty straight forward, one of the pipes has 5 bends in it. Not sure if i´ll pull that off :)
    This one is more complex, where the inlet for the CPU goes BEHIND the GPU.
    And the other one just trough the GPU and down.
    Its really tight pulling anything in front of the GPU due to case width (only 160mm)
    Bending testing goes well, the left one is done.
    Doing some testing with the right one, trying to run it paralell with the other.
    Quick notice...
    The black PSU/Floor shroud is NOT the final finish.
    Black paint is just a easy way to see scratches and other surface damages needed to be fixed :)
  11. HCP
    HCP Minimodder
    19 May 2012
    LOL, i´ll stay at about 60 in this one, not one soldered either ;)
  12. HCP
    HCP Minimodder
    19 May 2012
    Ran out of pipes, so i got stuck.
    Yesterday i got a message that the delivery will take alteast 10 more days...
    So, i did some testing...
    And, i´m just stuck again, i like the copper in some way, and the acrylic in another.
  13. jodah175
    26 Oct 2006
    thats a tough call because both copper and acrylic looks good. XD
  14. gavbon
    6 Feb 2013
    Looking good!
    Subbed :D
  15. Cheapskate
    13 May 2007
    The copper looks like it flattened a bit too. :( I guess we'll be seeing you in 11 days.
  16. HCP
    HCP Minimodder
    19 May 2012
    A quick mockup pic. before the last teardown. Some small stuff to fix still.
    The sleeving for example, orange did not go well with this :)
    Next up is leakcheck and final pics tomorrow i hope :)
  17. nimbu
    nimbu Multimodder
    28 Nov 2002
    Did you find that the aluminium parts could have done with a little better finishing. Every edge I have found is super sharp
  18. HCP
    HCP Minimodder
    19 May 2012
    My edges is real smooth and not sharp at all.
  19. HCP
    HCP Minimodder
    19 May 2012
    Some pics after it was done.
    Wish i spent more time on the GPU, its sagging a bit, but lifting the pipe the pipe started to sag instead.
    Focus for this project was the reservoar solution to make it visible trough the window, instead of the SSD as original.
    The top part with the copper/gold accent color.
    The outsides, looks pretty much like the Pandora out of the box.
    Exept for the reservoar :)
    The insides
  20. Iain Stott
    Iain Stott What's a Dremel?
    14 May 2009
    Very nice, love the copper tubing
