Hardware AMD Ryzen 7 1700 Review
Discussion in 'Article Discussion' started by Combatus, 8 Mar 2017.
  1. Combatus
    16 Feb 2009
  2. Vault-Tec
    30 Aug 2015
    Hurrah. Yes, definitely seems this is the one to have :)
  3. Journeyer
    Journeyer Minimodder
    31 Aug 2006
    Reading this makes me all warm and fuzzy inside.
    Now I'm even more anxious to receive mine, but I was dumb enough to order the Gigabyte Aorus board - which isn't in stock until the 10th apparently. Which means I will not get it until tuesday next week at the earliest since mail delivery during the weekends was stopped last year. I'll be sitting over here in this corner biting my nails until then...
  4. Combatus
    16 Feb 2009
    Board stock levels are poor across the...board :) Even system builders are having a tough time at the moment.
  5. Guest-23315
    Guest-23315 Guest
    Its like having an Opty 144 all over again
  6. Journeyer
    31 Aug 2006
    Lovely (Insert mandatory "I see what you did there" comment).
    I just went onto Komplett's web-pages to check the status on my order; they have updated the delivery time to: 10th of March - unconfirmed.
    *The biting of nails intensifies*
  7. Combatus
    16 Feb 2009
    I barely have anything to review either. WIth the Z270 launch, I was swimming in boards. This time, I can count the samples on one hand with digits to spare.
  8. tristanperry
    tristanperry Minimodder
    22 May 2010
    Great review :) Yes it definitely looks like the 1700 has 'lucked out' wrt the binning process.
    And as a side note, as you point out in the intro, an 8c16t 65W TDP CPU seems a pretty good achievement IMO.
  9. faugusztin
    11 Aug 2008
    And when the board is available, UPS is slow to deliver (my case) :rolleyes:
  10. Journeyer
    31 Aug 2006
    It does indeed.
    I'm hoping I get it before spring sets in; we're currently having negative temperatures which means my tank of coolant sits just below zero at the moment. Really anxious to see how the 1700 fares under such conditions. :geek:
  11. Anfield
    Anfield Multimodder
    15 Jan 2010
    Poor indeed, scan, overclockers, ebuyer, ccl and aria have a combined grand total of zero x370 boards in stock.
    Even in America it isn't much better, newegg who is the unchallenged global leader in being able to get stock only has one single X370 model in stock and three B350 ones.
  12. sandys
    sandys Multimodder
    26 Mar 2006
    Makes you wondered if some issues were found with early BIOS and manufacturers have held them back.
  13. Wakka
    Wakka Yo, eat this, ya?
    23 Feb 2017
    I wonder if this was AMD not being able to provide enough chipsets to the manufactures, or the manufactures just not producing many boards in fear of another Bulldozer flop?
    Or
    *dons conspiracy hat*
    Maaaaaybe there is plenty of boards out there in back rooms, but the retailers are artificially restricting access to them to bump the prices???
  14. Combatus
    16 Feb 2009
    I dare say that has got something to do with it, especially as CPU samples are readily available.
  15. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    Quick question: was your review chip bought retail by yourselves or supplied by AMD? I'm not suggesting any shenanigans but we've all seen cherry-picked components supplied for review whilst the off-the-shelf items are somewhat of a lottery.
    Just seems a bit odd that your 1700 oc's to a higher frequency than your 1800X, but I guess we'll see if that pattern holds as more and more folks get their hands on retail parts and crank them up to the max :D
  16. David
    7 Apr 2009
    I had high hopes for the 1700, and looks like the one to get - as things progress, apps and games are going to utilise more cores/threads - it's nice to see AMD back in competition.
    If I was in the market for an upgrade, I'd be looking at a Ryzen 1700 above all else.
  17. Anfield
    Anfield Multimodder
    15 Jan 2010
    Between reports of some Asus boards bricking themselves due to a bios issue, MSI and ASRock having to release updates to even get CPU multiplier selection to work and the issues with Ram speeds that caused tons of reviews to only use 2133 plus reports of massive stability issues with all four Ram slots filled it wouldn't surprise me if manufacturers are only drip feeding the market on purpose to avoid destroying their reputation while working on the bios quality behind the doors.
  18. Combatus
    16 Feb 2009
    Sounds like we had it easy with our memory issues and a few random failed boots then :)
  19. Broadwater06
    Broadwater06 Minimodder
    10 Apr 2016
    Please about that. At last there's a worthy boot up the Intel's arse, some real competition.
  20. faugusztin
    11 Aug 2008
    This is some serious trolling by the UPS. I got the CPU (1700), the cooler (NH-D15 SE-AM4), the SSD (1TB MX300), GPU (GT 710 PCI-E x1 - yes it is a server, so even this is an overkill for a text console, but at least it only eats one x1 lane)... Meanwhile UPS failed to deliver the board 2 days in row.
    I hope they are not going to try to deliver between 10:00 and 12:30, when i will have to be at work :D.
Tags: Add Tags
