News Samsung announces 1ms monitor
Discussion in 'Article Discussion' started by CardJoe, 5 Oct 2010.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. Loafers
    Loafers What's a Dremel?
    18 Nov 2009
    I doubt most consumers would be unable to differentiate between a 2 and 1ms monitor in a double blind test.
  3. Bauul
    Bauul Sir Bongaminge
    7 Apr 2007
    Of course they wouldn't. IIRC, tests demonstrate unless you're looking at two images that really contrast (like a full black and full white screen), no body can notice something that quick.
    Think about it - a response time of 0.001 seconds versus 0.002 seconds. It's pointless.
  4. danielleil
    danielleil Can't stop spending...
    20 Aug 2009
    Sounds like old news, I live in China and bought one of these from www.newegg.com.cn back in May. Cost worked out to around 250 quid and it is a great monitor.
  5. Showerhead
    Showerhead What's a Dremel?
    11 Jan 2010
    I assume this is still a grey to grey transition. If not it's impressive I've never seen a black white black transition go anywhere below 5ms
    Also Viewsonic beat them to it
  6. SMIFFYDUDE
    SMIFFYDUDE Supermodders on my D
    22 Apr 2009
    Nobody will notice the benefit of 1ms responce time over 2ms in real life. I'd prefer manufacturers get back to making reasonably priced 24" monitors with 1920x1200 resolution instead of slicing an inch of screen off with 1080 res.
  7. azrael-
    azrael- I'm special...
    18 May 2008
    As long as it's still a 60Hz TN panel this isn't really interesting. Give me a 120Hz xVA or IPS panel with LED backlighting and I'll get excited. :)
  8. cgthomas
    cgthomas Cpt. Handsome
    20 Oct 2009
    What's the refresh rate?
    Will it shatter the image ghosting barrier in 3d?
  9. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
  10. Teelzebub
    27 Nov 2009
    +1 :sigh:
  11. PabloFunky
    PabloFunky What's a Dremel?
    19 Sep 2010
    Why is it that even a 1ms response time seems way worse than a 0ms response of a crt?
    Im assuming its because a crt is a raster scanning device ?
    Still waiting for the day when we have a thin tft screen with the spec of a crt, i know its getting close, but were deffo not there yet.
    I assume theres many gamers on here that still swear by a crt?
  12. wyx087
    15 Aug 2007
    ah, my eyes! it's TN!
    i'll take IPS over TN any day, even if it's 1ms vs 10ms advertised speed.
  13. B1GBUD
    B1GBUD ¯\_(ツ)_/¯ Accidentally Funny
    29 May 2008
    Wake me up when they can offer a decent resolution, a 27" panel should be 2560 x 1440.
  14. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    you don't get it.. crt not only lag free it can display 120fps while it's at it- the new generation have no clue and they get tossed like a salad against a good player on a crt
  15. wyx087
    15 Aug 2007
    Dell U2711?
    Apple 27 inch?
    and may be Hazro HZ27Wa?
  16. chrisb2e9
    chrisb2e9 Dont do that...
    18 Jun 2007
    I miss having a crt... such quality images. Too bad the "good" monitors we have these days just can't compare.
  17. NethLyn
    NethLyn Minimodder
    24 Apr 2009
    Well I do, just because I've concentrated on the internal upgrades and the budget meant I wasn't gaming over 12 x 10 for a long time. So my first flatscreen wouldn't be for gaming, more just the web and general windows if I could get a good deal.
  18. knuck
    knuck Hate your face
    25 Jan 2002
    1ms or not, at 60hz it will still be full of tearing
  19. Gradius
    Gradius IT Consultant
    3 Feb 2009
    LCD will always have that "laggy" problem, even if is 0ms !
    You read me right, ZERO ms!
  20. Burdman27911
    Burdman27911 What's a Dremel?
    26 Mar 2007
    I highly doubt it. It likely also uses a TN panel with overdrive to achieve the 1ms response time, so it'll have artifacting instead of the "ghosting" which I even find to be worse...
    Marketing win = consumer loss all around.
Tags: Add Tags
