Anyone know where to buy these http://www.performance-pcs.com/cata...t_info&cPath=60_923_925_933&products_id=32290 other than from performance pcs. Not paying $50 shipping on 20 of these connectors and pins to suit.
Does it have to be that one ? http://www.aquatuning.co.uk/product...nector-4pin-PWM-plug---UV-reactive-green.html
Well, in that case : http://www.frozencpu.com/products/1...nnector_-_UV_Brite_Green.html?tl=g51c387s1555 http://www.frozencpu.com/products/1...Fan_Connector_-_UV_Green.html?tl=g51c387s1555 If you don't need it right now, then 20 pieces would cost you $15 plus $7.99 for shipping (USPS First Class International (15-30 days)). That would be even under the customs VAT limit i guess.
Awesome thanks kicking myself I bought another lot of stuff earlier today from there but could not find these on the site at the time thanks for your help much appreciated
If they didn't ship yet you could try to contact them. I had very positive experiences with FrozenCPU, one of the cables i ordered from them has been delivered damaged (one of the pins was disconnected), few hours after i asked how to do the RMA i got the answer that they already shipped a replacement for free .
Says in t&c that you have to phone to alter order. Would cost more than the $8 postage to ring from Australia to the U.K Did consider it though. Now just to buy some wire locally and wait for these connectors to arrive and I can move forward with my project.
digikey.com mouser.com but finding the part... that's another story... they are quite... well stocked...
Have major issues trying to find anything on those sites its fairly easy when you know the proper name for things, not so easy when you don't ended up buying from frozen cpu cheers.
Is there any guides etc for making your own cables which pin is for what housing is there a male and a female pin for the small 3pin and 4pin fan connectors? Got the housings right but a little stuck on how the pins work(I know you crimp them but don't know how the pins mate together male and female?). Help appreciated.
