Hi, Anyone heard of Ruilian Science fans especially the RDH1225S. Are they any good?, the one I have seems to knock out a fair amount of air but as I never used these size fans before I can't compare it to anything else. Cheers Herbs.
Cheers, i done a search on most of the web engines too, Im lazy but not that lazy before I post . Ta anyway. Herbs
If it intrests ya, i used a program called Copernic, it checks a load of search engines at once and normally pulls up some results. Fors
I know this is being a cheeky monkey but what about freeway design 12025 (i think its that model) case fan, its 120mm size. Ta herbs
Heres another place i found it. If you go to Google you can usually just type the fan code in and it comes up with results.
Ta, just me being stupid didn't even give it a thought that several companies may use the same manufactured fan DOH herbs
