Planning Need help finding them rubber bits - dremel help
Discussion in 'Modding' started by Otis1337, 21 Jul 2015.
  1. Otis1337
    Otis1337 aka - Ripp3r
    28 Nov 2007
    I'm going to be getting the old dermal out on my mates case as his new GPU is to big for his case. the power cables stick into the side panel stopping it from closing.
    so was going to cut the side panel so the cables can poke out a little.
    so it don't look a mess and to help the cables from not getting cut im looking for the rubber grommet used in cable management holes in cases or something similar. Just a strip of rubber that can slip onto the metal will do.
    any help? :dremel:
  2. Otis1337
    28 Nov 2007
  3. Teelzebub
    27 Nov 2009
    Yeah I've just bought some on eBay too, if the panel is perspex I would probably heat it and bubble it so it clears
  4. mingingbollock
    mingingbollock Minimodder
    15 Mar 2004
    Easiest way is to drill or small hole saw the two ends and cut/join em up with the dremel .
  5. Otis1337
    28 Nov 2007
    dont have the bits needed and dont want to buy them for this one little job but will ask about if any of my family have them. its going to be 1.5" by 2". sure you can do something so small with drill bits?
  6. Arboreal
    21 Jan 2011
    As you said, if it's metal, you could draw out the shape, and drill round the edge with small bits and either jigsaw it or break the part out with a file,
    The rubber strip will hide any small imperfections. :dremel:
