Scratch Build – In Progress Project: FO3 Wasteland Ranger - He Lives!!
Discussion in 'Project Logs' started by TheGreatSatan, 5 Feb 2012.
  1. TheGreatSatan
    TheGreatSatan Member for 17 years!
    5 Aug 2005
    Fallout 3: Wasteland Ranger
    I've been wanting to do a theme case for the game Fallout 3, but I've had little luck with picking the proper look
    I was recently looking at Troy Fryfogle's Hellusion mod that he built years ago and even though I've seen it so many times, I was finally inspired.
    So, I ordered my own mannequin
    Except, I'll be using the whole mannequin
    I'll also be adding some interesting accessories, like this Nerf gun
    Mine will need it to look real
    I'm going to be recreating the clothing too and making him look like a California Ranger from Fallout New Vegas, but not completely like the picture
    I got these cool kneepads
    My boots from when I was in the military. I'll go back and roughen them up later
    And my old duty belt
    Then I threw it all together with this one piece coveralls
    Just thinking A-Head here
    I ordered this gas mask on eBay. It came all the way from Lithuana!!
    He's almost too pretty to cover up...
    First I put on the black hood. I don't want his eyes visible through the mask eyes
    And then I stuffed it all in the mask
    And set it back on. Looks just creepy enough!
    More to come
  2. Cheapskate
    13 May 2007
    Kinky...:lol:
    I suspect you will be cutting the useless fingers at some point? -Needs the 'Kung-fu grip' for holding weapons. I also see some biker armor in your future.
  3. TheGreatSatan
    5 Aug 2005
    You are psychic!
  4. Vetalar
    Vetalar *learning english*
    21 Jun 2011
    excellent!!! FO 4ever!!!
    better add some "muscles" to this metrosexual body... until this it looks like a pencil in bucket :)
    and IMHO You have to remove all stickers/logos from equipment...
    maybe football player armor (greetings from nearly ALL post-apocalyptic movies)
  5. peteski
    peteski long live the pc
    8 Jun 2011
    like it . can i ask where are you it looks like a computer parts graveyard:D
    :rock: :rock: :rock:
  6. l3p
    l3p www.^.nl
    1 Nov 2010
    Oh man, something completely different! Sub'd!
  7. TheGreatSatan
    5 Aug 2005
    My basement/modding area
  8. modscases.com
    modscases.com What's a Dremel?
    29 Oct 2009
    wow very cool man keep it up
  9. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    This needs a Fat Man or at least one of the laser guns
  10. TheGreatSatan
    5 Aug 2005
    I finally got around to cutting him open
    And it's roomier than I thought
    Actually, 8 inches should be plenty
    I put in a Micro ATX motherboard (just a dummy) and discovered my first obstacle. The mannequin has an arched back and the motherboard will not be able to lie flat
    I want to use this video card inside
    An even though it's a 3 slot beast it will still fit
    First I'll have to remove the arch
    I'm going to cut it out and then add some aluminum following the line and making it flat enough for a motherboard tray and stand offs
    Remember, he's going to be wearing clothes and no one will no what his back looks like anyway
    Let's get to work
    And there goes that. It's very easy to cut this stuff
    This sheet of aluminum was once in my R2-D2
    I just have to mold it into place and then rivet it down
    After that, I put tape on the rough edges so I don't get cut up later on by mistake
    Now I need a motherboard tray and this case is garbage anyway
    I use the dummy board again to make sure it lines up right
    But I'm not sure how to make it stay in place so I rely on an old buddy: Expanding Foam
    Once the foam dries I'll remove the board
    I've come to realize that I won't be able to use such a huge video card anymore, but it's OK because I have many others
    Now I need to make a place for the PSU, so I cut what I need
    I predrilled out the holes for the rivets
    After I cut it out I put the frame on the inside
  11. jhanlon303
    7 Sep 2006
    Will PSU fit warped like that? My mannequin put the PSU in the bottom .
    john
  12. kelmannen
    kelmannen What's a Dremel?
    5 Feb 2011
    looking good! fallout rocks! got maaaaany hours in the series =D
    You should check this guy out!
    REALLY good looking ncr helmet made of cardboard! =)
    Ps. I did NOT make it! Belongs to the poster of the video!
    Ps#2. how do i get the youtube tags to work? tried a couple of times but don't get it =/
  13. TheGreatSatan
    5 Aug 2005
    Now that the foam is dry I was able to take the bad board out
    I put the torso back on the legs so I could take a look at my progress
    My gas mask hoses came from Lithuania too
    I started to think about cooling. The PSU will be exhausting hot air out of the case, but I need at least one more fan doing that. I really only have room for one 80mm fan under the right arm
    So, I used my holesaw
    And the skull grill from my Treasured mod
  14. TheGreatSatan
    5 Aug 2005
    I picked up this leg brace, but not for the mannequin
    I pulled the metal support struts out
    ANd then broke his right arm
    So I can give him an elbow that bends
  15. Guest-23315
    Guest-23315 Guest
    Yay. Modding.
  16. Cheapskate
    13 May 2007
    It's beginning to look like you should have started with a skeleton. You'd have all the articulation, and would look d*mnned scary through the goggles. I doubt the expanding foam will stick for long. If you can't rivet, how about drilling a bunch of holes and stitching the board tray in place with bell wire?
  17. Vetalar
    21 Jun 2011
    For expanding foam - 2/3 of used cars in our country has it as a repair/shape stuff in it :) and no problem witu wearing off. Oh and that cars from lithuania too :)
    send from my BLADE via tapatalk
  18. TheGreatSatan
    5 Aug 2005
    I have expanding foam in my R2-M5 that is years old. It's nearly impossible to get rid of and is exceptionally strong. I have clothing still stained with it years after I wiped my hands on them
  19. Vetalar
    21 Jun 2011
    While this foam is strong - leave it under the sun and it became brown and dusty. It very UV sensitive.
  20. TheGreatSatan
    5 Aug 2005
    Like all my mods as of late, this will be on display at the store where I work
