Hello All Anyone here have any experiance with this? I have a script that a customer has asked me to deploy on a LAN. I have never used it and the customer isnt sure either (it came off another server).
I'm not sure why you would want to even deploy that. Looking up what it does you can do all this easily from Group Policy.
It's set to map some drives and add a couple of printers. From what I can see I need to add the KiXtart files and script in the NETLOGON folder in Sysvol.
you have to use a bat file to call the kix32.exe and then the kix file Use it on a customers network for the moment
Agreed with everyone here - deploy the config via group policy, not via a KIX script... even in XP you can do almost everything via GPOs and it only got better from Vista->7->8 etc. Mapping drives http://technet.microsoft.com/en-us/library/cc770902.aspx for instance
