Storage Problems with new set up
Discussion in 'Hardware' started by Minitoz, 7 Jun 2016.
  1. Minitoz
    Minitoz What's a Dremel?
    29 Jun 2010
    Hi there,
    Recently, I took the plunge and bought a SSD. I've installed it and decided to upgrade to win8. After the OS installation, I unplugged my optical drive as it's no longer needed and plugged in my old 2tb HDD. Everything is going well except when I try to copy my iTunes folder from my external HD to the old HDD,i get a message on screen telling me the operation can't be completed because 'There isn't enough space on Local Disk. You need an additional -681357312 bytes to copy these files.' I'm a bit stuck with this as it will allow me to copy over individual folders but there's no way I'm copying over 1000 folders one at a time.
    Any advise will be greatly appreciated.
  2. SuperHans123
    SuperHans123 Multimodder
    27 Dec 2013
  3. Minitoz
    29 Jun 2010
    Cheers. Sorted now.
  4. Minitoz
    29 Jun 2010
    Ok, that didn't do anything. I can copy files up to roughly 10gb but anything more and it gives the same message.
