Small Form Factor Steam 'console' revealed
Discussion in 'Hardware' started by Parge, 8 Jan 2013.
  1. Parge
    16 Jul 2010
    Story here
    "It Begins: Valve And Xi3 Team For ‘Piston’ Steam Box"
    Engadget article here
    CNet
    Official Xi3 site
    No specs confirmed at present, but what we do know is.
    Quad Core
    Has a 40W power envelope
    Fully modular - allowing you to upgrade.
  2. GeorgeStorm
    16 Dec 2008
    Not a fan of the looks, but will be keeping an eye on it regardless.
  3. Tangster
    23 May 2009
    Looks fugly to me. Could see it being a modders favorite though.
  4. Fizzban
    Fizzban Man of Many Typos
    10 Mar 2010
    Looks ok to me, but it's what it can do that will interest me, or not.
  5. Parge
    16 Jul 2010
    I personally can't really see the market unless its super cheap.
    Those that use steam regularly can probably build their own systems, or if not, can buy from one of the many companies out there that can.
    Everyone else is going to be a console gamer, and thus tied to either Playstation or Xbox and their exclusives etc.
    I'm also surprised that Steam haven't designed and produced the hardware themselves instead of outsourcing it. In fairness, that isn't really their 'market', but I wouldn't be surprised to see them do it in the future (like Apple who now design their own ARM SoCs)
  6. xpronic
    xpronic What's a Dremel?
    22 Nov 2005
    With this, Project Shield and Ouya, 2013 is looking very interesting for casual gaming. I'll be picking the cheapest one and using it as a portable htpc/mini gaming system lol.
  7. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    I assume that's not the final production case for the one they'll be making for Valve.
  8. fuus
    fuus Misses Rep Bombs
    4 Dec 2010
    I can imagine proprietary connectors for graphics cards. I.E. no modular upgrade unless you buy one with a valve connector...
  9. Guest-23315
    Guest-23315 Guest
    Was hoping for something flat and sleek, a la a DVD/Blu-Ray player.
    Gabe I am disappoint...
  10. halfinched
    halfinched What's a Dremel?
    19 Jul 2010
    looks good to me. the move away from blu-ray and dvd into streaming and downloads means it doesn't have to look like a flat rectangle. I quite like the cube form factor, plus at that size you can tuck it away so you don't have to see it! Just a question of what it can do now.
  11. mrMonkeyChunks
    mrMonkeyChunks EVGA Cheesecake
    4 Mar 2012
    It may be 'modular' but I imagine there will be some use of proprietary connectors on the motherboard, forcing you to by special parts from valve and their partners rather than being able to shove a 3570k in there for example.
  12. Parge
    16 Jul 2010
    I would say it would be, Xi3 use the same chassis for all their products
    I would say you'd be correct, given the form factor and internal layout
    So was I, would have made it much easier to place in peoples TV cabinets which usually have long and thin shelves.
    I'd say you would be correct, especially given the current power envelope and the fact that the cooling has to keep up with whatever parts you buy.
    Also, it will allow them to make money from upgrades (ie: if you upgrade to a GPU that costs £80 in the shops, they might charge £100 for the steambox version)
  13. Burnout21
    Burnout21 Mmmm biscuits
    9 Sep 2005
    I actually like it, not in the purple but the flat black. Hopefully they'll dump the chrome end plates for a nice gloss black.
    As for upgrades, I doubt it'll ever be an issue as long as it's capable of the next gen of source engine.
    everything done by valve with the current source engine runs fine on hardware as old as the 8800GTX and earlier. That's the beauty of the source engine, which makes it no different that a console really. Spec the under pinnings of the hardware and game engine and release to dev's.
    Hopefully it'll see better driver support as well to really milk the hardware for all that's it worth
  14. Tangster
    23 May 2009
    I wanted something reminiscent of the portal designs.
  15. kenco_uk
    28 Nov 2003
    I hope it'll have a fair bit of grunt as it'll need to run games other than just Valve's, it'll need to run all those available on Steam.
    I quite like it, but it doesn't need so many of the ports on it. Just a power port, hdmi, optical audio out, GigE nic and a couple of usb ports would do. I presume there'll be space inside for one or two standard 2.5" HDD/SSDs.
  16. mucgoo
    mucgoo Minimodder
    9 Dec 2010
    I'm guessing the form factors largely so they can just use a single 80/120mm fan?
  17. Yslen
    Yslen Lord of the Twenty-Seventh Circle
    3 Mar 2010
    Looks like it's APU powered. It's going to have to be outrageously cheap for anyone to want to buy a box that only runs a few source games or indie titles and does nothing else. Then again, the microconsole market seems to have emerged from nowhere, so perhaps that's what Valve is aiming for.
  18. Yslen
    3 Mar 2010
    I think you may be overestimating the size of the thing. It's absolutely tiny, unless that guy has massive inhuman hands...
    You may be able to add drives in that way (depends on the OS, really) but I imagine that's what all the ports are for.
  19. theshadow2001
    3 May 2012
    I like the aesthetics of it.
    This device could be great for linux users, that is if they maintain compatibility across this device's operating system and a mainstream distribution.
    On the other hand this device could also add to the further stagnation of the development of PC gaming graphics since clearly its not going to have super high end graphics capabilities (not least because it would be too expensive) If this steam box takes off it could set the upper limit of how elaborate graphics can be for a pc game.
  20. Burnout21
    9 Sep 2005
    Just been giving this some more thought.
    Valve need test bench hardware that is console sized without the ball ache of developing a platform from the ground up, and without the huge cost of such development. (just think how much sony and microsoft must have dumped into hardware development)
    So the little Xi3 is exactly that. Now think about the steam on Linux project, very small kernel on a SSD with "Big picture mode" as the UI. That makes for a very small install footprint before you add games. The drop in SSD's price's could see such a platform with 512Gb of SSD sweetness. Or teh kernel and steam are installed on flash memory on the board, with SSD expansion. (similar to the Xbox 360)
    My only fear is the AMD APU. AMD/ATI have been hugely painful since the dawn of time with Linux support being a joke.
    I would like to think this is the first stepping stone..
